motor swap for 02 f250
PLEASE HELP!!!!!!!!
I need to pick a ford enthusiast brain for a moment if I may.............
I have a 02 f250 2wd that I need to replace the 5.4 triton motor in (307,000 VERY HARD miles on it). Can someone help me with a question I have about it?
I found a 1998 e250 van with the 5.4 triton, will it fit, and what would I have to do to make it work with all the sensors on the computer in the f250?
Thanks for any information and wisdom I hope to receive.
Don't give up on us, you probably would have had better luck if you would have posted in the super duty forum, the answer to your question is yes it will fit but you might have to change over things like the intake manifold possibly the exhaust manifolds and your accessory's and brackets..
All depends on the maitenance history, it s easier changing plugs and coil packs with the engine out also look at the exhaust manifold studs because they are not fun to fix with the engine in either..
