1970 F250 grill insert - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 07-01-2013, 06:43 PM
4x4ford33 4x4ford33 is offline
4x4ford33 is starting off with a positive reputation.
Hey guys I'm looking for the grill insert for the passenger side of my 1970 F250. I can't figure out how to post pics from my phone, but rectangle and is divided into four smaller rectangles with two bars across the middle.
Old 07-02-2013, 02:47 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
Old 07-02-2013, 03:28 PM
The second one down is the correct one but it is my understanding that the one from 1970 is particular to that year, the 71-72 have slightly different dimensions.
Old 07-02-2013, 06:08 PM
GLR's Avatar
GLR GLR is offline
2nd one down is a 72. 71 is different as is the 70.
The 70 has 4 mounting screws. 71-2 has 6. They will interchange just not using the outboard 2 screws. Your 70 might have been changed over it's lifetime, you might have a 71-2 grille shell. Just went and tried a 70, a 71, and a 72 insert in a 70 shell. All fitted ok.
Old 07-02-2013, 06:34 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Your grille frame and the inserts are not correct for a 1970. Based on your description, the grille frame is 1971/72 (D2TZ-8200-A replaced D1TZ-8200-A), inserts are 1972 and are R/L specific.
1970 grille frame (D0TZ-8200-D) is 1970 only, has the tabs for the screws that retain the inserts in place...located in different positions than 1971/72.
1970 plastic 'egg crate' aka 'checkerboard' inserts are the same right/left (D0TZ-8150-B). 1970 inserts will not fit in a 71/72 frame, 1971/72 inserts will not fit in a 1970 frame.
Left: 1970 / Right: 1971/72: Inserts shown (D1TZ-8150-A Right & D1TZ-8151-A Left) are 1971 only, as 1972 inserts (D2TZ-8150-A Right & D2TZ-8151-A Left) have 2 center bars.
Old 07-07-2013, 05:37 PM
http://item.mobileweb.ebay.com/viewi...id=74968707089
I found this one on Ebay and messaged the guy, he said it has a r2 on the back side of it and thinks it's the passenger side, does that sound right?
Old 11-19-2013, 11:55 AM
djjsc djjsc is offline
djjsc is starting off with a positive reputation.
1970 grille insert
Have what you want here:
http://saskatoon.kijiji.ca/c-cars-vehicles-classic-cars-NOS-early-70s-F-100-grille-inserts-W0QQAdIdZ476294416
Old 11-20-2013, 11:15 AM
Thanks for the post, but there's no way I'm paying that much. I would just go with a billet grill if I wanted to spend that much money.
WTB 1970 Ford grille insert 70FE250 WTB - Parts & other 2 02-27-2016 04:49 PM
Need help asap stuck out in field...shorted column wire issue ford4x4s 1999 to 2016 Super Duty 23 06-23-2015 06:59 AM
2006 Lariat grille help gerk3 2004 - 2008 F150 3 12-28-2014 07:34 PM
cab wireing bozzo152 1987 - 1996 F150 & Larger F-Series Trucks 1 04-17-2014 04:57 PM
Grill for a 1970 f100 ford4x4nut 1967 - 1972 F-100 & Larger F-Series Trucks 12 07-10-2013 05:48 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
