2010 edge cabin fan noise - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 07-01-2013, 03:25 PM
bielaf bielaf is offline
bielaf is starting off with a positive reputation.
i just bought a 2010 ford edge today with 19xxx miles on it and when we test drove it the dealer had us do right hand turns and today when we drove it home and made a left hand turn no matter how fast or slow you turn the cabin fan make a sound like there is leaves in it but you turn right and it makes no noise what so ever any thoughts and ideas would be great thanks
Old 07-11-2013, 03:01 PM
FordService's Avatar
FordService FordService is offline
Official Ford Rep
FordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud of
Quote:
Hi bielaf,
I recommend bringing your Edge back to your Ford Dealership so they can perform an inspection. They'll be in the best position to get this accurately diagnosed and repaired for you. Let us know how things go moving forward; if you need my help, just give me a shout!
Crystal
Old 11-10-2013, 12:05 PM
hdbear hdbear is offline
hdbear is starting off with a positive reputation.
Theres a filter under the glove box,probably clogged.Easy fix
Old 11-10-2013, 12:09 PM
Change the cabin filter located under the glove box,easy fix.And don't store napkins in the glove box unsecured.Mine did the same it was loaded with leaves and dust,,,good luck
Old 11-10-2013, 12:21 PM
what it actually was was water the drain tube was clogged for the air conditioning so when you make a left turn the water would flood the fan th e dealership made us wait over the weekend before we could drop it off and they ended up replacig the fan as well
The Duck Bill - Secret rat entry point into a Bronco Torky2 1978 - 1996 Big Bronco 2 11-16-2016 11:21 PM
2005 v6 escape, cabin noise and vibration at idle 199930ranger Escape & Escape Hybrid 2 08-18-2015 07:19 AM
79 ford f100 need help dshowman 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-11-2015 10:48 PM
7.3 loss of cabin power fiddlesticks 1999 to 2016 Super Duty 3 04-28-2014 08:39 AM
steering wheel hiss kbsupercrew Brakes, Steering, Suspension, Tires, & Wheels 0 05-05-2012 08:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
