advance timing - Ford Truck Enthusiasts Forums
advance timing
Old 07-01-2013, 02:27 PM
yonu yonu is offline
yonu is starting off with a positive reputation.
advance timing
Hey all I have a 93 ranger with the 2.3 electronic timing and for whatever reason the timing is acting retarded and I am curious if instead of taking the belt off if I could advance the timing like a distributor and advance the plugs? Or will the ecumenical simply relearn and start acting up again.
Thanks,
Yonu
need help with 7.3 TPS adjustment yonu North Carolina Chapter 11 04-10-2015 09:00 AM
93 2.3l MAF sensor yonu 4 Cylinder Engines 0 02-03-2015 07:21 PM
looking for some help with my 2.3l Ranger yonu North Carolina Chapter 12 10-28-2014 06:19 AM
timing 351w yonu Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 07-01-2013 11:43 AM
Check engine light and low RPM help needed yonu Ranger & B-Series 31 04-29-2013 06:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
