Kiss one 4.9L goodbye
They're supposed to last to 300k, but apparently mine didn't. At 200k she's done. I have high crankcase pressure, causing it to leak oil from every possible place. I replaced the PCV and that didn't seem to help with the pressure, which tells me that it's likely rings.
Today it seems that I have no oil pressure below 1500 RPM's.
So it looks like it needs exploratory surgery and very likely a rebuild.
If I decide go that route, I guess it would be a great time to upgrade the cam, put in something that would appreciate the header a little more.
Suggestions?
Suggestions?
mine in the 87 lasted 125k it had a bad cyl since i bought it not knowing that then a mechanic looked at it said it was only running on 5.so i overheated the **** out it a month ago till the needle on the temp gauge was about an inch over the hot mark. then it quite in the road after it was knockng and all sorts squealing too. still turned over but hard an after it cooled it would run but not well and i believe i cracked the block. owell ive been working on a 87k motor for it and almost ready to go.
Now I'm weighing the options of having a local machine shop rebuild it and putting a cam in it, or getting a long block with a warranty.
hav24wheel
04-17-2010 04:38 PM
MDK
07-07-2005 09:14 AM
fatdaddy
02-14-2003 11:25 AM
