July BS Thread
#31
Have you tried dielectric grease? I have been going thru my grounds as well and globing a dab of dielectric on then. I did find a comparable grease at Tacoma Screw. Forget the name. But just ask. Came in a large tube. Having a truck that's ten years younger than me all the wiring is suspect.
#32
Carb removal, rebuild, install should be about 1.5-2 hour job, unless you want to hand polish the thing.
If you're going to rebuild a Carter AFB (Edelbrock) then spend the couple extra on a Marine accelerator pump, as this is a sealed unit and better.
I'll give you my old battery cables as I'm putting in 00 ga battery cables and I believe you can use "corning oil" in place of Dielectric grease.
#33
#34
Baking Soda/water mix or Coca Cola will clean it off. Clean it, rinse with water (distilled if possible), coat it with Dielectric or something comparable and I would suggest super glueing a couple pennies about a 1/4 to each side of the connection and one by each battery post.
The reason for the pennies is that copper acts like a magnet to the electolisis buildup and it will attract it away from the less conductive/stronger components, just check to make sure they are still there every once in a while as it will completely dissolve the penny over time, don't put the penny by the Positive post between the post and anything it can ground out on.
Should be about the cheapest way (I can think of) to solve your problem.
#35
#36
You have a 400 with a high mount alternator and the ground should be connected to the lower left corner of the left head (looking at motor from front which is incorrect orientation from a mechanical standpoint).
My point is, you could put at least 20 pennies in the available space.
Putting them on the battery is just a precautionary measure to prevent it from becoming an issue.
#37
#38
#39
#40
I know I know, you mean parts. Only a few I'm really after. I need at least 2 more dually wheels and tires, it only came with 4. And some tailgate and tail light stuff, it didn't come with either. I put some 87 up tail lights in it, they work fine. And have a louvered 5th wheel tailgate I think will work great and match the look I'm going for but I need one more of the latch parts that attach to the bed. 80-86 is different then 87 up, hmmm wonder if it's the same as 73-79. It's a vertical bar attached with 2 tapered bolts, 87 up is a pin just like a door pin.
Other then that it's all good, of course there is lots of stuff I could use, ie seats. I actually need good front seats for 2 of my trucks. I like the newer bucket seats with the seat belt built into the seat back. So keeping an eye out for a good deal on a set I can make work. On the 86 I want to keep a real 80s thing going and it has some aftermarket over plush captains chair type seats from a factory outfitter and only the drivers is messed up, so I think I'll fix it. I'll have to snap a pic when I get the interior a little more cleaned up but don't really want to put anything into it until I get the title BS dealt with.
I got it running and know it's a solid truck, that is all I need to do for now to know it's worth dealing with the State over the title BS. Course this all changes if I can't sell the 86 for decent money cause of the title issues. I like it but for me I'd have to convert it to 4wd and diesel to make it a keeper. I really only bought the truck($300) cause I wanted the rear axle(10.25) and maybe the engine (460 with 93k) and the rest of the truck was a free bonus. But damn it's too nice to part out, it'd be such a waste. It's a nice truck I'd like to put it up for sale for a fair but high price to get an owner that will appreciate it and I'll hang onto it until I find hat person. But all that falls apart if I can't get the BS with the State worked out.
#41
I have those BMW buckets, lol.
Snap a photo of the tailgate part if you you get a chance, on here or text it. There's a great yard by my place but my cash is tied up in order to float costs on parts or it would be quite a drive for you. NWAutoRecyclers they have an inventory of vehicles with photos on their site but actually update Craigslist more often.
#42
Yeah I remember you mentioning those. I don't think they would work out well for me and I don't see paying much for them.
What I'd like to find is a great deal on a full set(all 3 rows) of leather seats out of something like a Tahoe/Yukon that had the second and third row buckets. But like you my cash is tied up and I don't see finding a deal I can afford real soon.
Edit, hmmmm these look goooood and comfy
#43
#44
#45
