4x4 front wheel bearings-lubrication - Ford Truck Enthusiasts Forums
Old 07-01-2013, 11:48 AM
garydmundy garydmundy is offline
garydmundy is gaining momentum as a positive member of FTE.garydmundy is gaining momentum as a positive member of FTE.
I just replaced both front wheel bearings (166,000 mi) because I had to replace a bad all joint and I was there. I was kind of mad that I had to buy the whole bearing/hub so I decided to tear the old one apart and see why you could not replace the bearing only.
First, the small roller bearing that you can easily see as most of you know is not the wheel bearing but the axil support bearing. It is removable and you can easily get a new one and install it yourself (Torrington part # B-2110) The large nut holding down the wheel bearing is a Bitc#$% to get off but it can be done. Under that is the top of the wheel bearing which has the manufacture and the part number on it plus a warning. With a hammer and punch, I got the metal top off the bearing. It had a o-ring under it that sealed it. Under that was a rubber gasket that further sealed the bearing. At that point, I had to use a cutting torch to cut the hub in two. There are two rows of bearings and the bottom is also sealed.
My point of all this is to tell people that filling up the hub with grease through the vacuum port WILL NOT GREASE THE WHEEL BEARING, it will only grease the axil support bearing. This bearing is double sealed (0-ring plus rubber gasket). This would be like putting grease on the outside of our sealed u-joints and expecting the grease to lube the bearings. I also wonder how much resistance all that grease makes when the temp. are very low.
Oh, yes these bearings are not serviceable in my opinion.
Old 07-01-2013, 12:59 PM
01PS 01PS is offline
01PS is starting off with a positive reputation.
You are correct. The point of the removable zerk is to grease the needle bearings.
Old 07-01-2013, 01:42 PM
bakerbuilttracks's Avatar
bakerbuilttracks bakerbuilttracks is offline
bakerbuilttracks is starting off with a positive reputation.
Very true..... I have unplugged my vac line to my hubs and installed a zerk for Lubing the axel carrier bearing. And every 10k I pull my abs sensor and install the grease fitting I bought from clay at RR to lube the actual wheel bearings. Not entirely sure if the grease through the abs sensor reaches the wheel bearings but when I removed the sensor the first time I noticed a lot of grease down in the hole.
Some say that this method will reach the wheel bearings for sure. But I am not certain it will. Can you see from what you torched in half if you pumped grease in there it would reach the wheel bearings ?
Old 07-01-2013, 04:03 PM
lhud lhud is offline
lhud is gaining momentum as a positive member of FTE.lhud is gaining momentum as a positive member of FTE.
Just my $.02 but I am going to disagree as I also pulled a failed front bearing hub apart without having to torch anything and took pics of it disassembled. You can view those pics in my profile in one of my albums. The ABS opening is in the middle of the inner and outer main bearings. This opening is directly over the 'gear wheel' that the ABS sensor looks at and I do not think there is anything else separating the two main bearings. Therefore the grease can work itself to either bearing.
Old 07-01-2013, 08:32 PM
IHUD, I do believe you are mistaken. The vacuum port is not located in the wheel bearing hub assembly, it is located in the assembly that supports the upper and lower ball joints. The wheel bearing assembly bolts to this support but it is not part of it. When you cut the wheel bearing assembly in half, you can see that the grease you would get by using the vacuum port would only go around the top of the bearing. Just because the vacuum port is located roughly where the middle of the wheel bearing is, the bearing is still sealed and grease cannot get into it. It is sealed 360 degrees in all directions.
Old 07-01-2013, 09:20 PM
bigb56's Avatar
bigb56 bigb56 is offline
bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.
When you say "vaccuum port" are you referring to the ABS sensor hole?
Old 07-01-2013, 11:02 PM
DaveCinIN DaveCinIN is offline
DaveCinIN is starting off with a positive reputation.
The vacuum port and the ABS sensor location are 2 different places. The grease goes in the ABS location after the sensor is removed.
Old 07-02-2013, 01:30 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Quote:
I believe someone in this thread is confused.
Pop
Old 07-02-2013, 05:56 PM
I agree Pop. I only mentioned the ABS sensor opening is where we add the grease and as seen in my pics it is centered on the two main inner/outer bearings.
Old 07-02-2013, 10:34 PM
bigb56's Avatar
I am still confused if the OP is mistakenly referring to the ABS hole as the vacuum port, or if he is thinking we put grease in the vacuum port.
Old 07-03-2013, 12:50 AM
<snip><snip>{snip}
OK, you do it your way, then.
Pop</snip></snip>
Old 07-03-2013, 01:22 AM
puller45's Avatar
puller45 puller45 is offline
Seasoned User
puller45 is gaining momentum as a positive member of FTE.
Quote:
Pop</snip></snip>
Some things just ain't worth arguing about. A man convinced against his will is a non-believer still.
1995 4x4 Bronco/F150 Wheel Bearings & Seals and Mile Markers Tim Hodgson 1987 - 1996 F150 & Larger F-Series Trucks 1 02-08-2015 07:31 PM
1995 Bronco Wheel Bearings & Seals and Mile Markers Tim Hodgson 1978 - 1996 Big Bronco 0 02-08-2015 01:56 PM
in case it happens to you. here's the answer. fordfan32 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 11-18-2013 02:08 AM
Thrust washer front axil 2001 F250 4X4?? RodneyWise 1999 to 2016 Super Duty 2 11-27-2012 01:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
