anyone have any suggestions? - Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
Old 07-01-2013, 06:13 AM
zstangkrewson's Avatar
zstangkrewson zstangkrewson is offline
zstangkrewson is starting off with a positive reputation.
I have pulled the 4.9 out of my 1990 ford f140 and have put in its place a 1995 5.0 v8, everything is bolted up and now we have an issue with the dash wiring and Especially the ignition switch wiring, does anyone here have any experience cross wiring these two wire harness to get the ignition to work?
any help is GREATLY appreciated.
Old 07-01-2013, 07:22 AM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Just hook up the power feed to the Dura spark to switched battery, and the solenoid trigger from the ignition switch to the "S" terminal on the solenoid. It's not a complicated system.
Old 07-01-2013, 07:47 PM
LOL have you seen how many wires are under the dash??? it took me almost an hour to remove teh dash, 45 min of it was unhooking wiring! but ill give it a looksy! thankyou for the reply!
Old 07-01-2013, 08:03 PM
I know there's plenty of wires under there, ...but only two matter.
Old 07-02-2013, 09:30 PM
there was 8 wires coming out of my old switch, and now there is 12 wires from the new one, old has 2 yellow, new has 4, hmmm this could get interesting.... had to cut on my mint dash to get the new instrument cluster to fit, looks pretty good i think..
Old 07-02-2013, 10:07 PM
Use a test light to see which wire goes to starter trigger. Same thing for the switched battery.
Old 07-09-2013, 07:32 PM
no luck yet, am going to swap cabs and fuel/tailight harness and see if i get anything, right now all i get is a check engine light and thats it...
can crank the motor with the selenoid, but no fuel or spark.
on another note, i test drove a 97 f150 with the 5.4, had a rattle in the motor, fro mwhat ive seen on youtube and google, sounds liek the cam phasers are worn out, so i think, not for me...
Wiring diagram needed Shwan_89HD Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 08-08-2014 09:47 PM
Ignition 2 Wire WVBassFan 2004 - 2008 F150 0 01-11-2014 05:42 PM
Flathead Ignition Wires cts1954 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 03-11-2013 03:01 PM
ignition 1975 viperassasin 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-03-2006 03:24 PM
VSM Wiring RAMPAGE_F350 Electrical Systems/Wiring 2 03-25-2006 10:17 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
