What type of synthetic oil to use? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 07-01-2013, 01:11 AM
Rus01 Rus01 is offline
Rus01 is starting off with a positive reputation.
What is the best types of synthetic oils to use in my 6.4ltr??
I used to use Chevron Dello 400 synthetic 5W40 in my 7.3ltr and had great luck with it and the motor is till running strong. I just don't know if i can use that same oil in my 6.4 ltr though?
Old 07-01-2013, 10:01 AM
Delta2142's Avatar
Delta2142 Delta2142 is offline
Delta2142 is starting off with a positive reputation.
I use Rotella T-6 Any oil you use needs to be CJ-4 rating
Old 07-01-2013, 10:10 AM
wp6529 wp6529 is offline
wp6529 has a good reputation on FTE.wp6529 has a good reputation on FTE.
Any CJ-4 rated 5W-40 synthetic from a reputable manufacturer should be fine. In my opinion this excludes Amsoil products. I've had good UOA reports in some 90,000 miles with Mobil1 5W-40TD @ 5k interval changes and UOA at every change.
Old 07-01-2013, 11:45 AM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
I use mobil 1 as well, and my UOA's have been great!
Old 07-01-2013, 06:40 PM
Is 5w40 ok for a summer oil?
Old 07-01-2013, 06:52 PM
What about CG-4 rated? 0W-30
Old 07-01-2013, 10:46 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
I've been running Motorcraft as Ford has done ALL my maintenance for 70,000 miles. I'm switching to Rotella T6 since I was able to snag quite a few gallons at $13.99 a gallon.
Old 07-08-2013, 04:23 PM
speedyfz1's Avatar
speedyfz1 speedyfz1 is offline
speedyfz1 is starting off with a positive reputation.
Quote:
Amsoil sells 2 products that meet the requirement:
Premium API CJ-4 Synthetic 15W-40 Diesel Oil
Superior Shear Stability and Extended Drain Intervals in Ultra-Low Emission Diesel Engines
The premium choice diesel oil for model-year 2007 and newer heavy-duty and pickup truck diesel engines requiring API CJ-4 emission-quality oil standards. Delivers extraordinary lubrication in diesel engines in commercial, fleet and personal applications. Exceeds modern specs for emission-quality diesel oil.
Premium API CJ-4 Synthetic 5W-40 Diesel Oil
Maximum Fuel Economy and Extended Drain Intervals in Ultra-Low Emission Diesel Engines
Old 07-08-2013, 04:33 PM
rufushusky's Avatar
rufushusky rufushusky is offline
rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.
Yes, it is still a 40wt oil per SAE J300 therefore it behaves like any other 40wt multigrade oil at operating temp. It will be fine.
How old is that? CG-4 is a pretty out dated standard at this point. I would just run a CJ-4 oil. They are easy enough to come by.
Old 07-08-2013, 09:08 PM
fordtruggy's Avatar
fordtruggy fordtruggy is offline
fordtruggy is starting off with a positive reputation.
I run Rotella 5W40 in mine.
Looking For Advice Drew Fleming 1999 to 2016 Super Duty 2 01-04-2015 01:52 PM
Synthetic ATF instead of type F belchfire Clutch, Transmission, Differential, Axle & Transfer Case 8 11-12-2014 08:05 AM
Lost power steering and power breaks!?? Rus01 6.4L Power Stroke Diesel 6 04-08-2014 12:08 PM
99 f-150 4.6 ltr overhead cams use lifters? DanK5 1997 - 2003 F150 1 03-31-2014 02:46 PM
Delo 400 0w30?? Rus01 6.4L Power Stroke Diesel 0 09-08-2013 05:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
