69 and 73 frame dimensions
In 73 the frame was widened and lengthened at the rear of the cab back. The measurements are same from the rear of the cab to front bumper 65-79.
The FE will bolt right in. Bring the drivers side frame perch with it as the 73 should have power steering that you might also want to swap along with the front axles for power disc brakes.
John
Jesus, those diagrams are confusing! I'll try to analyze them though.
So, what you guys are saying is that in the front, the only area that matters for a swap, the frames are the same, meaning I can just swap engines as well as mounts and all that without any or much fabbing? If so, that's great!
The OP asked about an engine swap, that area is the same. If he had wanted to place the engine in the bed it might have.
Correctomondo! No fabbing at all.
John
John
Awesome! This is excellent news. It makes my life a lot easier. When my '69's tranny is rebuilt and installed, I'll pull the '73's 360, rebuild it as a street performance 390, then simply throw it in. I can't wait! The only issue would be the exhaust, but I'm best friends with a guy that has a metal fab shop in his back yard.
FE right (passenger) side engine support (aka tower/stand/perch) is the same: 1965/76 F100/250 2WD & 1967/76 F350.
There are two different left (drivers) side FE 2WD engine supports.
(1) 1965/68 F100/250 & 1967/68 F350.
(2) 1969/76 F100/350 with or without P/S.
lilraven96
09-06-2016 02:48 PM
jseim44
12-16-2009 02:37 PM
