302 and 351 intake questions
So from what I've been reading the 5.0s have square ported intakes lower and upper and the 5.8s have the round. Well my 92 5.0 does have the square on both lower and upper. My 351w I just got to swap in has square lower intake ports but the upper intake was round. And I know the upper was a 5.8 because it has the ford EFI 5.8 logo. But is the lower a 5.0 because it's square? I thought the 5.0s wouldn't fit a 5.8. So is it possible I have a 302 with a 5.8 upper intake on it? Because I bolted my original 5.0 upper to the new 5.8 lower and fits perfectly. Just looking for some input because I'm don't know that much about these intakes, thanks for any help
on
Yes you have been duped, a 5.0 lower will not bolt to a 5.8 block because it is taller and wider so the heads are also further apart. You can ID the block by examining the area where the distributor plugs in, if the surface is roughly level with the intake gasket surface you're looking at a 5.0 while if it's about an inch below the gasket surface it's a 5.8 block.
A 5.0 Block..
A 5.8 Block...
A 5.0 Block..
A 5.8 Block...
Those 5.0'S with the staggered intake ports have the GT40 or GT40P heads and were given the "Cobra" style intake which matches the better flow of the GT40 heads.
Thanks Conanski it is definitely a 351. And yeah i just have the standard middle truck lower intake. But my 5.0 upper intake works just fine on it, im not sure what all the talk I have heard and seen on it about a 5.0 upper not working on a 5.8 because it works fine. Thanks for the input guys
on
If the motor you got has the lower portion on the left you have a 5.0 motor not a 5.8.. that lower portion will not bolt on a 5.8 motor the lifter valley is too wide.. the 5.0 intake is only about 9" wide while the heads are about 11" apart on the 5.8.
I do have the one on the left. But it is a 5.8, at least according to what you said Conanski. The distributor area sits an inch or so lower than the 302 block I have. Also the head bolts are bigger. And it is a wider heaver block. So how do you explain that lol if its not a 351 and its not a 302 than what is it?
