1966/1979 body swap
1966/1979 body swap
I have a 1966 f250 2wd, and a 1979 f150 4wd. I would like to put the 66 body on the 79 frame and running gear. I know that you can cut out a small section of frame behind the cab on a 79, and shorten the frame so the wheel on the 66 bed line up proper with the 79 rear end. My problem is that my 79 is a short box. Can the frame on my 79 be lengthened in the same area to get the same results. (By the way I also posted this on the 73-79 page)
Thanks, 66f250
Thanks, 66f250
33 1/2" width between the inner frame rails behind the cab: 1961/72 F100/350 / 1973/77 F250 4WD (High Boys) / 1973/79 F350: Cab & Chassis & on the 140" wheelbase.
All other 1973/79 F100/350's have 37 1/2" rear frame rails.
1965/66 F100/250 2WD & 1966 F100 4WD with 8' beds: 129" wheelbase.
1967/72 F100/250 with 8' beds: 131" wheelbase.
1973/79 F100/250 Regular Cabs with 8' beds: 133" wheelbase.
1973/79 F100/150 Regular Cabs with 6 1/2' beds: 117" wheelbase.
profive0auto
27
01-18-2012 11:46 AM
apachetech
02-02-2006 07:23 PM
