Voltage stabilizer yes or no? - Ford Truck Enthusiasts Forums
Old 06-30-2013, 11:13 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
Ok I'm looking to get a voltage stabilizer for my truck which works to ensure power is supplied at all times at a constant rate and if there is any power loss or spikes, what I am trying to figure out is would such a thing be worth using in our trucks sinse there are ones built for home theater systems that do work well so there is plausibility to using one in a truck to ensure power is delivered at a constant to all things requiring power.
What I want is a good descussion on it, the pros and cons and why, thanks for all your help in helping me keep my truck running!
Old 07-01-2013, 12:02 AM
zombie_killer's Avatar
zombie_killer zombie_killer is offline
zombie_killer is gaining momentum as a positive member of FTE.
My understanding is your battery already serves as a voltage stabilizer. The only reason I could see for using one is if you have 18v or 24v accessories installed on your rig.
Old 07-01-2013, 12:07 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
What you're describing is a CAPACITOR Jaime...Stores energy and releases it to smooth out the "Waves"..
They're worth it, but only for 1,000w + stereo systems, and HUGE subwoofers.
But zombie is right...That's what the battery (Stores/releases energy) and the Voltage Regulator (Keeps the voltage stable) does for the truck.
Old 07-01-2013, 12:10 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Like a stiffening capacitor on a stereo right?
I ran my stereo without one when I first hooked it up to make sure all the speakers and amp worked and the headlights pulsated to the beat pretty spectacularly.
I don't really see a benefit unless there is a huge power draw (like a big stereo set up or the like).
However, I don't really see a downfall unless something were to create wiring gremlins.
Old 07-01-2013, 12:13 AM
Big_Al59 Big_Al59 is offline
Big_Al59 is starting off with a positive reputation.
I would think home theatre stuff would be 110. Don't know why you would need a stabilizer in either place. If your alt & voltage regulator are working you shouldn't see enough change to make a difference, unless your running a mega watt stereo system or operating a winch.
Old 07-01-2013, 03:01 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Honestly I don't see any reason to do this, unless your running a ridiculous stereo.
Old 07-01-2013, 09:36 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
Capacitor? Screw those things... that's 1700's technology. Now we have these things...
Fuel Doctor USA | Official home of the revolutionary FD-47
I bought one at my local parts store and got a few more MPG... so I thought well gee if I can use ONE and get better mileage... why not buy more? I added power receptacles everywhere... on the instrument panel, console, seats, even in the bed, and put a Fuel Doctor in each one. Now my mileage is so good, I ain't bought gas in a week.
Oh wait... that's cause it's been parked all week.
Yeah in all seriousness though, you should have fairly stable and clean power. If your voltage regulator is working right and you don't have large intermittent electrical loads, your voltage should be stable. Your alternator generates 3 phase AC, and has a full-wave rectifier to convert it to DC (of course losing the inherent efficiency of AC in the process) so if anything, you could have ripple current on your system from failing diodes. Usually this is seen as lights that have a pulsing glow to them. You could always take a multimeter and measure for frequency... you should have little or none.
I do wish that automotive electrical systems would actually USE the 3 phase AC that the alt puts out... and just use the DC for starting, battery charging, lights, etc. Things that can't benefit from 3 phase. Would need a way to stabilize the frequency output though, which would require a constant speed drive... which is an additional cost and you know car makers these days love to pinch pennies.
Old 07-01-2013, 09:22 PM
AdrianJR's Avatar
AdrianJR AdrianJR is offline
AdrianJR is starting off with a positive reputation.
Throwing in my 2 cents worth here...
The older name for a 'storage battery' is an 'accumulator' - as others said, its function is to act as the reservoir for the alternator's output and help it provide a stable supply.
Old 07-01-2013, 09:27 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
Your truck and EVERYTHING else with a battery is DC powered, you won't get any spikes with DC.....You are wasting your time and money. you MIGHT get a slight voltage drop when turning on large powered accessories but within milleseconds the voltage regulator will up the output of the alternator and you will be back to normal power.
On edit I see Dixie replied better then me...That's what I get for not reading all of the posts....
Diesel Rod
Old 07-01-2013, 09:55 PM
Dixie460 you almost trolled me. I must admit I was getting ready to click on fuel doctor link until I got to the second half of your post. I commend you.
Bottom line is this...If it ain't broke, don't fix it!
Old 07-02-2013, 08:41 AM
Jaime74656's Avatar
Jim
Ok cool, so what I was thinking really seemes to go with your alls comments, its not really worth it and I am not really planning on a super sound system, just new speakers, head unit and a decient sub just to round out my music...
Old 07-02-2013, 08:53 AM
dixie460's Avatar
Yeah, if that's all you got you'll be fine without any modifications. Just make sure all your connections (battery and elsewhere) stay clean and tight.
Old 07-02-2013, 09:14 AM
Jaime74656's Avatar
Jim
Quote:
thats whay im planning also going to look into replacing the factory grounding wires too if needed
Old 07-02-2013, 09:26 AM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
Just to add to the discussion, the above advice on skipping the power conditioner is what I would also give, but you could also look at the big 3 upgrade (term used in the car audio world). What you replace with the big 3 is the alternator to positive battery cable, the negative battery to chassis ground, and the engine to chassis ground cables. This will help insure that the alternator and battery respond as quickly and with as little resistance loss as possible to transient power spikes.
For additional electrical upgrades you may also want to look at a headlight relay harness that pulls power directly from the battery rather than routing your headlight power feed to the dash switch and back. This will greatly reduce line resistance as well as improve the longevity of the headlight switch.
Old 07-05-2013, 08:12 PM
Jaime74656's Avatar
Jim
Is there a link to the head lamp harness you speak of I remember seeing it here some where and tried to find it again but couldn't, would rather get one that is 100% plug and play if able, also any recommendations on the big three upgrade? I'm trying to find a good grounding upgrade kit as well.
BDS Dual Stabilizers (99-04) Review A/Ox4 1999 to 2016 Super Duty 8 07-05-2014 07:30 PM
Fuel and Temperature Constant Voltage Resistor / Regulator old broke prospector 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-05-2013 10:27 AM
Voltage Stabilizer for Instrument panel 66 F100 ford66 1961 - 1966 F-100 & Larger F-Series Trucks 25 11-19-2011 03:53 PM
Best Towing Set Up! CPTMidnight Excursion - King of SUVs 16 08-01-2010 01:19 PM
Bilstein Steering Stabilizer Firemudder 1999 to 2016 Super Duty 11 04-16-2010 12:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
