Head bolts reusable? - Ford Truck Enthusiasts Forums
Old 06-30-2013, 10:01 PM
truckpastor truckpastor is offline
truckpastor is starting off with a positive reputation.
I can't seem to search very specifically in this forum. In the case I pull my yblock heads off for service...are the bolts reusable? Can't find a bolt set for sale anywhere like other engines I've worked on.
Old 07-01-2013, 09:41 AM
Gregxlt's Avatar
Gregxlt Gregxlt is offline
Gregxlt is starting off with a positive reputation.
I'm not sure, maybe ask over on the Y block forum. I know ARP make a set, Mummert's has them for sale.
HOME Y
Old 07-01-2013, 10:29 AM
thanks...I also came accross this set Ford Y block page 272,292,312 cylinder head bolts,dowel pins and freeze plugsFord Y block page 272,292,312 cylinder head bolts,dowel pins and freeze plugs for sale for $90.00 seems ridiculous for pieces of metal. BTW I haven't pulled head yet, but due to my INTJ personality type I over analyze everything and plan ahead just in case. I wan't to know what surprises may creep up.
Old 07-01-2013, 10:38 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
I've reused Yblock headbolts all my life without a problem
Old 07-01-2013, 04:51 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
I have not rebuilt a Yblock but if I were to, I would reuse the head bolts. They were made of real stuff, not like the modern day disposible ones! I have reused the bolts from a 223 in-line and a 352 a few years back without incident.
Old 07-02-2013, 07:29 AM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
I reused my head bolts when I rebuilt my Y-block with no problem. I am an engineer and yes the bolts are stretched a little when torqued and in a perfect world you should replace them. However, unless they have been torqued and un-torqued many times, over torqued or you are building a race engine with high compression, there is no real problem reusing them. The torque numbers are not that high and the compression is not that high. My opinion, you mileage may vary.
Old 07-02-2013, 06:04 PM
spurredon's Avatar
[quote=Walston;13304898] I am an engineer quote]
You kind of disqualified yourself with that remark in my view!
Old 07-03-2013, 05:45 AM
Walston's Avatar
[quote=spurredon;13306419]
Still laughing......
Been a member of FTE for nearly 10 years and it is the first time I admitted it....LOL
Old 07-03-2013, 10:23 AM
thanks guys. I'm used to the newer "torque to yield" bolts that always need replaced. I was shocked when changing a head gasket on my taurus a year ago how much they stretched compared to the new one's length!
Head bolt question 7.399 1999 - 2003 7.3L Power Stroke Diesel 7 08-12-2016 11:15 AM
Head gasket #01truckfan 1987 - 1996 F150 & Larger F-Series Trucks 2 09-11-2015 05:03 PM
78 F150 351 Need Exhaust Manifold Bolts and Gasket Question plcdwg101 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-04-2014 12:54 AM
Head bolts. Reusable or not? Pikachu 1999 - 2003 7.3L Power Stroke Diesel 23 02-08-2014 06:11 PM
What to do about flywheel bolts? damarble 1987 - 1996 F150 & Larger F-Series Trucks 16 10-25-2012 09:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
