Mustang II Rack - Ford Truck Enthusiasts Forums
Mustang II Rack
Old 06-30-2013, 09:31 PM
SCD SCD is offline
SCD is starting off with a positive reputation.
Mustang II Rack
I am trying to get my steering shaft routed around my headers. I have a Mustang II Front end and a Tbird rack. Is there reason why I cannot shift the rack an inch or two towards the driverís side of the truck to help get around the headers?
Thanks
Scott
Old 06-30-2013, 09:52 PM
Kurt G.'s Avatar
Kurt G. Kurt G. is offline
Kurt G. is starting off with a positive reputation.
Moving the rack to either side from center changes toe angle. This may not seem like much but it will change how much inner tie rod shaft and outer tie rod have in contact on threads. Have you looked into the universal knuckles ( don't know what the actual name is) ? Personally I would not shift rack over. Just my 2cents.
Old 06-30-2013, 10:32 PM
topmoo's Avatar
topmoo topmoo is online now
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Agreed! Don't move the rack, it will change the steering geometry.
Old 07-01-2013, 10:36 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Yes, there is a big reason why you should not move the rack. The steering geometry is designed for the rack to be in the exact place for the tie rods to move with the control arms. Altering that will induce bump steer and dangerous driving conditions. Do not move the rack. Move the engine, get different headers, or work with steering linkage, but do not move the rack.
Old 07-01-2013, 11:11 AM
SCD SCD is offline
Well, I guess that answered that question. Thank you all for your replies.
Scott
Old 07-01-2013, 11:41 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Pictures would help us give you suggestions of what you can do. If the engine and headers fit with the stock box, then the shaft should be able to be routed around. What engine, headers, and column + length are you using?
Old 07-01-2013, 12:02 PM
tip49's Avatar
tip49 tip49 is offline
tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.
Steering clearances
Once you've got your cross member installed, rough in your steering shaft. My setup clears my exhaust headers by about 1". I modified my left motor mount so that my steering linkage passes through it, with two Borgeson U-joints and a steady bearing off the frame.
Old 07-01-2013, 05:46 PM
topmoo's Avatar
I used a wood dowel rod the same diameter and cut it to make it a double D so it would go in to the U-joints. Mine has a SBC so it is different, but I made my own motor mounts that avoid the steering shaft.
Old 07-01-2013, 06:14 PM
SCD SCD is offline
I am trying to post some pictures, but I think the ones I have are too large. I will take new ones tonight. What I have is a 56 F100 with a Mustang II front suspension. I have a 4.6 DOHC engine out of a Mark VIII. The steering column is a modified (steering box removed) stock column with a Fordomatic shifter. The headers are Sanderson. The way it sits now, the shaft from the rack is pointing directly at the collector on the header. The collector is heading straight down at that point. The rack shaft is only a few inches from the collector. If I ditch the headers, and use Cobra manifolds the issue goes away. That may be what I have to do.
Old 07-01-2013, 06:57 PM
SCD SCD is offline
I posted some pictures in my gallery
Old 07-01-2013, 08:00 PM
AXracer's Avatar
OK, I see your problem. First thing I'd suggest doing is contacting Sanderson. Since this is a relatively new, but gaining in popularity engine, I'm sure they would like to hear about interference issues like this. I have found them to be very responsive and helpful in past dealings, and they may even offer to make you a new header that will clear, or at least be willing to take back the ones that don't fit.
Old 07-02-2013, 09:34 AM
SCD SCD is offline
AXracer
good idea, I will contact them today. Thanks everyone for your input.
Scott
Old 07-02-2013, 10:59 AM
AXracer's Avatar
I'd be really interested in hearing what they say.
Old 07-02-2013, 11:00 AM
SCD SCD is offline
I will let you know.
Old 07-02-2013, 04:35 PM
SCD SCD is offline
AXracer
I just got a response from Sanderson and they stated "We do not have anything that would work, and our custom build schedule is backed up right now. I spoke to Francisco and he said we could offer you a "kit" where you could have someone build a header for the driver's side. If interested, please call . . ." I asked if I could return the headersa and they said yes! That is the kind of company that I like to deal wiith. I am very impressed with Sanderson and would deal with them again in an instant.
Thanks everyone for their help.
Bro's new rig turbohunter 1973 - 1979 F-100 & Larger F-Series Trucks 29 03-21-2016 02:00 PM
manual MII rack and pinion hwyhogg 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-10-2015 10:20 AM
Mustang II power rack rebuild jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 05-27-2015 03:22 AM
Steering issue Mustang II Baldy66 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 07-21-2014 09:58 PM
Steering column help needed - 51, 302, Long Tube Mustang ii PS Effin-Yeti 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 06-18-2014 07:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
