Speedo recalibration - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 06-30-2013, 07:19 PM
Aussie BrianB's Avatar
Aussie BrianB Aussie BrianB is offline
Aussie BrianB has a good reputation on FTE.Aussie BrianB has a good reputation on FTE.
Question Speedo recalibration
Hi all,
My truck has 315/75 R16 rubber fitted and so the speedo is out,
enough to get fined.
It also makes keeping an eye on fuel consumption difficult.
Is there a way to recalibrate the speedo or do I need to buy one of these?
TruSpeed™ Speed Sensor Recalibrator · Superlift · www.superlift.com
Old 06-30-2013, 11:27 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
There isn't a way to correct the speedo on theses trucks. (newer ones can get the speedo reprogrammed)
How much is your speedo out?
Old 06-30-2013, 11:36 PM
Enough to get fined, when the speedo says 100km the GPS says 112km.
Old 07-01-2013, 06:58 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
U can recalibrate with AE which I have. Where do you live ??
Never mind I just saw the city of churches. No good to you
Might ask Reg if he has it
Old 07-01-2013, 07:22 AM
Brian,
Pardon my ignorance but what's AE?
Old 07-01-2013, 11:57 AM
Old 07-01-2013, 07:28 PM
Adrian,
WOW what and great piece of equipment!!
Unfortunatley its a bit of overkill just to recalibrate the speedo.
I don't know if I would get enough use out of it to warrant the
cost and freight to Australia.
Old 07-02-2013, 06:05 AM
its well worth the money imo. has full diagnostic provisions, data logging and much more. Its the first thing I get out when i got a problem with the truck. Saves some yobbo charging you $100 bucks an hour and changing parts will nilly. Get ya data, post your problem on FTE and problem solved.
Old 07-02-2013, 06:15 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Analogue speedo recalibration:
1) check GPS and indicated speed difference at 100kmh;
2) remove insturment binnacle cowl;
3) carefully remove speedo needle rest pin (pull gently with needle nosed pliers);
4) let needle come to it resting position, note position;
5) using a lifting fork, gently level the speedo needleaway from the cluster - without too much effort the needle will come off;
6) refit the needle to a new position to obtain the speed differential correction as noted in 1) above, the needle just presses on;
7) re-fit cowl & binnacle cover;
8) next time you're on the highway check the speed differential again, if necessary repeat the above until you have 100kmh spot on.
If you are running larger than stock wheels the above will mean that your speedo will proportionally read UNDER your GPS/actual speed below 100kmh.
Old 07-02-2013, 06:19 AM
If my memory serves me correctly we dont have a instrument cowl. Its all one bloody big piece and a absolute PIA to get off
Old 07-02-2013, 06:25 AM
Simon,
Mate ifs that's the only solution then the AE suddenly sounds like
an attractive option.
Old 07-02-2013, 06:29 AM
Brian,
From my experience anything involving the dash of any vehicle is a PITA, and the neck and the back and, by the end, the head.
The dash has to be my least favourite place.
Old 07-02-2013, 06:45 AM
It's not that hard! Prize out the headlamp switch and unplug it, the entire cowl (including dash) unclips, once you get it started it is easy to unplug the 4WD loom, twist it over and stick it on the passenger seat. From there you can unclip the perspex instrument cover and access the gauge needles.
I've had this lot out countless times & replaced all the bulbs with LEDs cause then I figured that I wouldn't have to do it again.
The actual dash stays in situ.
Anyway, I have to take mine off again because one of the LEDs is flashing - why did I bother? So I'll take some pics of the operation and post them.
Old 07-06-2013, 04:21 AM
Nkelly's Avatar
Nkelly Nkelly is offline
Farkall User
Nkelly is gaining momentum as a positive member of FTE.Nkelly is gaining momentum as a positive member of FTE.
Old 07-16-2013, 04:14 AM
Bought the AE from RR, waiting for it to arrive.
How hard is it to recal the speedo with the AE?
What speedo cal. Brand is still around? Reddhorse 1999 to 2016 Super Duty 7 02-22-2014 05:10 AM
another speedo question 2020 1987 - 1996 F150 & Larger F-Series Trucks 2 01-19-2014 04:57 PM
Need help locating the ABS Module for a Superlift Truspeed Install Bowie 1999 - 2003 7.3L Power Stroke Diesel 20 08-12-2009 08:22 PM
Superlift tru-speed sensor.....anybody? UP_There 1999 to 2016 Super Duty 64 01-16-2008 05:25 PM
Superlift Truspeed Install Help 02superstroker 1999 to 2016 Super Duty 7 08-17-2003 11:18 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
