trying to get the old beast runnin...help lol - Ford Truck Enthusiasts Forums
Old 06-30-2013, 01:06 PM
blueriverbob blueriverbob is offline
blueriverbob is starting off with a positive reputation.
So I got my 55 f250 home. Decided to keep it 6 volt as I just want this to be a budget restore to a putting around truck. Got a new battery and installed. 6.1 volts at the battery. 4.6 volts at the coil (but not sure what its suppose to be). Turned it over and it seemed to turn over very slow (however I am not versed in 6 volt so don't know if that is normal), and seems to be no fire at the wires or its so weak I cant see it (guess I could talk the wife into touching it lol).
The truck ran about two years ago and has sat since. I am thinking to start at the starter and taking it apart to see if its just hanging up inside and not getting enough rotation.
Feel free to chime in for assistance lmao. I just feel great that it turns over. Thinking that anything that will turn over will eventually start I have pics posted on my album and for 1,000 bucks I think I got a good deal still.
Blue River Bob
Old 06-30-2013, 01:52 PM
Kurt G.'s Avatar
Kurt G. Kurt G. is offline
Kurt G. is starting off with a positive reputation.
Welcome Bob are you familiar with the 6v system? my 55 was pos ground and also did not like starting. I converted to 12v but honestly 6v will be fine if all is working ok.
Old 06-30-2013, 02:19 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
I'd check battery cables and connections. I would not dig into the starter until I knew I had to. You can use a volt meter and find where the most voltage is dropped while cranking. That will point to any bad connections or maybe even burned starter solenoid contacts.
Old 06-30-2013, 02:32 PM
Mr Mayo's Avatar
Mr Mayo Mr Mayo is offline
Bring out the best!
Mr Mayo is starting off with a positive reputation.
Don't overlook the importance of good, clean ground connections.
Old 06-30-2013, 05:30 PM
All advice taken and thanks. I started at the battery and right of the bat the pos to the relay has a 6 inch wear to about 1/4 in the wire. Going to replace all cables and a new regulator. The start of my receipt keeping
Old 06-30-2013, 06:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
AutoZone or similar battery cables are NOT sufficient for 6v. You need cables that are #00 gauge. ("double aught") It's the nature of these engines to crank slower than you'd believe, even when all is well.
Old 07-01-2013, 02:14 AM
tnguynaford's Avatar
tnguynaford tnguynaford is offline
tnguynaford is gaining momentum as a positive member of FTE.
Congrats, Bob, and welcome
Just a couple thoughts...
Remember that it is a positive ground system.
And the coil should be getting battery voltage when key is in run position.
Old 07-02-2013, 08:16 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Did you install the battery positive ground? Did you clean and gap the points, then time the distributor?
As others have said you need good condition, large diameter, battery cables. Take the battery cable ends loose and clean the connections.
Also, make sure someone didn't install a 12V coil at some time in the past.
Old 07-02-2013, 09:06 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Bob,
You don't want to keep receipts & track the truck expenses. No.... bad idea .. You want to be able to deny all knowledge of costs... "Oh I just bought this truck thingee when I was buying you that real nice xxxx...".
Good luck over there in Oregon!
Ben in Austin
1950 F1
Strange Charging/Alternator issues eman588G 6.0L Power Stroke Diesel 6 06-11-2015 03:06 PM
1947 Pickup 12 volt conversion questions CADLAC 1947 and Older Ford Trucks 7 10-21-2014 11:21 PM
Starting problem sammatt1 Excursion - King of SUVs 11 03-24-2014 02:00 AM
advanced stereo/security wiring thoughts kornfanjoe Excursion - King of SUVs 15 02-06-2013 07:35 AM
F250 5.4L battery light comes on and off acf6 1999 to 2016 Super Duty 7 04-11-2012 08:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
