Valve Springs - Ford Truck Enthusiasts Forums
Valve Springs
Old 06-29-2013, 09:35 PM
Elkgrovemichael Elkgrovemichael is offline
Elkgrovemichael is starting off with a positive reputation.
Valve Springs
Howdy all,
Does anyone know if the 360 FE motor has "rotator valve springs" or not? I`m putting in a bigger cam and want to replace the old ones. But in makes a difference as the two have different installed hieghts, and I have been unsuccessful in finding out on my own. Thanks in advance.
Old 06-30-2013, 05:44 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
Compcams has a chat available on their site where you can talk with a tech. If you tell them what you have they will recommend proper springs, retainers & locks for your application.
Old 07-01-2013, 12:25 AM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
Pull your valve cover and L@@K ezzzzzzzzz. And If you don't know what rotator valve RETAINERS cups look like do a search. PS Some had them. i Found them on the mirror 105 blocks like D4 smog heads....orich
Broken valve spring Larry85355 Modular V8 (4.6L, 5.4L) 4 02-22-2013 10:38 AM
sonnax valve waste of money.. 89ford73 1994.5 - 1997 7.3L Power Stroke Diesel 1 09-19-2010 02:01 AM
351C valve train specs 78SupercabPowerstroke 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 10-28-2002 01:34 PM
Do you need new valve springs with a Lunati Cam? unioncreek FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 03-03-2002 04:53 PM
351m valve springs fastredford 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 02-09-2001 05:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
