6.0 intercooler conversion - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 06-29-2013, 07:26 AM
Aussie BrianB's Avatar
Aussie BrianB Aussie BrianB is offline
Aussie BrianB has a good reputation on FTE.Aussie BrianB has a good reputation on FTE.
Question 6.0 intercooler conversion
Is converting the 7.3 intercooler to the 6.0 one worth the effort?
Is there an aftermarket one that does a better job than the 6.0 one?
Old 06-29-2013, 10:25 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Depends, it is a better intercooler, and if you are running a tune/higher boost, it's definitely going to drop your temps. I haven't fitted one (my truck is also un-tuned).
There are others that are bigger (I.e. better), but all of them that I have seen are more expensive.
Old 06-30-2013, 06:33 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Tossed this one up for a while now. Unless you are tuned to the hilt or are towing 20000pounds I wouldnt worry about it. Are you have EGT issues ?
Old 06-30-2013, 06:41 AM
Quote:
Brian,
Not having any problems at the moment but do intend doing the usual
mods and changing to a PHP tuner.
I'm not after extreeme performance just want respectable performance with 3tonne of caravan behind and a couple of hundred kg in the back of the truck.
I am more interested in reliability and longevity that drag race performance.
I have just found that the 4.2 turb landcruiser was struggling any time I
met an uprade and did not like hauling the van in 40 degree Adelaide summer heat.
I was just wondering if the change of intercooler would be a big help or just a few degrees less EGT for a lot of spanner swinging.
Old 06-30-2013, 03:19 PM
Nkelly's Avatar
Nkelly Nkelly is offline
Farkall User
Nkelly is gaining momentum as a positive member of FTE.Nkelly is gaining momentum as a positive member of FTE.
Quote:
In Victoria with the cooler weather most of the time I wouldn't be too fussed,but if I move to mackay I will be putting a bigger intercooler in,most likely the banks intercooler 30% more air flow it also comes with bigger intercooler pipes,colder the air more air flow the better our diesels go..
My Nissan patrol I had with the 4.2 intercooled was a different truck on a cold morning compared too a warm afternoon...
Im a BIG believer in the cold air induction,thats why im busting too get my air filter changed from the cone K&N intake too something else sucking air out of the engine bay is a performance downer I reckon
Old 06-30-2013, 05:26 PM
Dont forget water injection. U get cooler Egt's. can be applied when needed and a HP gain as well. When you are pulling a 3 ton trailer up a grade its gunna get hot. Even the best IC wont give you what you need. IMO.
Old 07-01-2013, 03:15 PM
Nkelly's Avatar
Farkall User
Hmmm looked at that,be a good thing why haven't you got it hmmm
Old 07-02-2013, 06:07 AM
Due to my own personal global financial crisis everything is on hold atm. But I do have plans. just dont tell MeMe.
Old 07-02-2013, 06:18 AM
Nkelly's Avatar
Farkall User
I know what ya saying, Frustrating all these things we would luv to do and no fekkin money aaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhh
Old 07-02-2013, 06:50 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Just when I want to buy from the US the ar$e drops out of the Aussie $ Not really complaining, at least it'll give our farmers/manufacturers/tourism industry some relief.
But now I need to save for a couple more months before I can afford what I could have afforded 2 months ago.
Old 07-02-2013, 03:05 PM
Yes we have had a good run. But like all good things they must come to an end. I think it was around .85 when I started investing in Clay's retirement fund.
Old 07-03-2013, 05:37 AM
Nkelly's Avatar
Farkall User
I had an excellent argument with lyn when it was over a dollar now im screwed
2008-2010 6.4L intercooler? Pele Excursion - King of SUVs 2 05-24-2016 12:44 PM
6.0 coolers fitting a 7.3 7.3 stroked out 1999 - 2003 7.3L Power Stroke Diesel 4 12-13-2013 11:32 AM
6.0L Intercooler Repair? bigpowerstroke 1999 - 2003 7.3L Power Stroke Diesel 3 11-10-2010 04:14 PM
6.0 Intercooler upgrade dakota joe 1999 - 2003 7.3L Power Stroke Diesel 1 06-26-2006 08:07 PM
intercooler 6.0??? banks??? leave the 7.3??? mtgrzlyman 1999 - 2003 7.3L Power Stroke Diesel 16 05-13-2006 11:03 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
