05 3 valve 5.4 timing issues - Ford Truck Enthusiasts Forums
Old 06-27-2013, 10:38 AM
Towster Towster is offline
Towster is starting off with a positive reputation.
Hellllp???!!!!!! Got an f150 05, 5.4 3valve,,,,, over last 12 months replaced both cam phasers, last one just 3 weeks ago, still had noise in engine (tic) heading to work it felt like half of the motor shut off, got quiete but missing badly, would not get out of its own way, towed it to shop, found a broken bolt in driver side lower chain guide walleyed out the oil pump bolt hole, and some wear on cover, replaced oil pump and all guides and chains and tensioners, started up, still missing, unable to determin where the miss is, scan shows left cam advanced and right cam retarded, how do you align the the timing, with out going to dealer????? And what else could it be,,,,, we did check for bent valves, and we seem to get good compression in all holes.
08 f150 knock f150guuy 2004 - 2008 F150 1 09-04-2014 01:59 AM
Difficult diagnosis! iamlance Modular V8 (4.6L, 5.4L) 2 04-20-2014 10:07 PM
05 Cam Phaser Rebuild Ford'05HG Expedition & Navigator 3 02-19-2014 04:37 PM
2004 F150 5.4 V3 timing kit JOSEF150 2004 - 2008 F150 3 10-13-2013 05:06 PM
2004 F150 3v triton Timing issue after sparkplug break tear down. Please help. dexterslab724 2004 - 2008 F150 3 06-13-2013 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
