What brand of shocks to use? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 06-27-2013, 10:03 AM
jp4lsu jp4lsu is offline
jp4lsu is starting off with a positive reputation.
I need to replace the rear shocks on an Expedition Limited with the coil spring set up. What brands should I look at?
Autozone and O'Reillys carry Monroe and KYB. Are these acceptable?
Bilsteins?
Eibachs?
Would these be better for ride and durability.
Old 06-27-2013, 12:25 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
with regards to shocks.....IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
5) Monroe- stay away from that junk!
Old 06-27-2013, 12:48 PM
Thanks Beechkid.
Sounds like KYB might be the choice here. I'm leary of Monroes and the big brands that these parts stores carry. So I felt I needed to ask about shocks since I'm not that well versed on these components.
The Expy has 20" wheels with 55 series BFG's, so I think a KYB shock should be a good selection based on your analysis.
Thanks and feel free to provide more info and analysis. Good stuff
Old 06-27-2013, 03:52 PM
Big Bad Big Bad is offline
Big Bad has a good reputation on FTE.Big Bad has a good reputation on FTE.
Bilstein HD, valving is about 20% stiffer than stock.
Being a monotube, high pressure gas shock with digressive self-adjusting valving (deflective disc), they have the same variable damping characteristics of the Edelbrock IAS or KYB GR-2, etc.
Lifetime warranty and track record is a plus.
Mustang II frontend shocks ungerp 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-29-2014 05:48 PM
whats a good brand of Shock Absorber Jr Camien 2004 - 2008 F150 6 02-23-2014 10:03 PM
F-3 Shocks? obscurity 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-05-2013 06:23 PM
Shocks For Leveling Kit on 1999 F250 SD 2WD F250Bruiser 1999 to 2016 Super Duty 9 08-11-2012 08:36 AM
Shock absorber recommendation tradosaurus 1968-2013 Full Size Vans 3 02-26-2007 09:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
