Gas and Temperature Gauge Issues - Ford Truck Enthusiasts Forums
Old 06-27-2013, 01:24 AM
JD_F100 JD_F100 is offline
JD_F100 is starting off with a positive reputation.
Question Gas and Temperature Gauge Issues
My gas and temperature gauges are registering Empty and Cool, respectively. I just replaced the fuses and everything else on the instrument panel is working.
Do I need a new sending unit from the gas tank? What about in the auxiliary tank? Both tanks register empty and when I flip the fuel switch on the instrument panel, nothing happens with the gauge.
As far as the temperature gauge is concerned, does that problem need a new thermostat?
Thanks for the help!
Old 06-27-2013, 09:38 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Remove the sending unit from the in-cab tank, remove the float and shake it to hear if gas is sloshing around inside.
Float made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
If float has been compromised replace it, then see if gauge works, same float used with auxillary tank sending unit which also might be compromised.
Float same: 1957/79 Passenger Cars/Trucks, 1961/79 Econolines & 1966/79 Bronco's.
Carpenter sells a one piece replacement brass float that will never leak for about 5 bucks.
Old 08-18-2014, 01:53 PM
alanblueeeee alanblueeeee is offline
alanblueeeee is starting off with a positive reputation.
I have a 79 f150 and the gas gauge wont move above E ! Help !!
Old 08-18-2014, 02:34 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Did you put fuel in it?
Sent from my iPhone using IB AutoGroup
Old 08-18-2014, 04:48 PM
quinletc's Avatar
quinletc quinletc is offline
quinletc is starting off with a positive reputation.
Subscribed. I have the exact same issue.
Will ground the sending unit tonight and then check the float, if necessary.
Now, I feel pretty confident that my gas tank gauge float is not causing the temp gauge to read cool - just a guess, but a good one, I think.
Is there a similar test for the temp sending unit? Can I pull a wire and ground it?
Are the regulators part of the sending units?
Old 08-18-2014, 04:53 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is online now
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Yes, ground both wires and the gauges should peg at highest reading.
Old 08-18-2014, 09:51 PM
Quote:
There's only one.
D1AZ-10804-A .. ICVR - Instrument Cluster Voltage Regulator-attaches to printed circuit board (Motorcraft GR-513) / Obsolete ~ Available NOS and from auto parts stores.
1971/72 F100/350 / 1971/74 Econoline / Misc 1971/79 FoMoCo Passenger Cars.
When the ICVR begins to fail, the needles of the fuel and temp gauges may do the "hula" .. swing wildly back & forth on their own.
When the ICVR fails, the needles will not move.
Old 08-19-2014, 12:53 AM
quinletc's Avatar
Half way there…
Well, for my fuel gauge, the problem is definitely the float. Sending unit and gauge seem to work fine, as long as there isn't a fuel-filled anchor holding the lever down at the bottom of the tank. Going to check NAPA and/or Ford dealer for a float and sending unit gasket tomorrow. If I strike out there, I'll order online.
Still don't know what the temp gauge problem is, but then, I didn't do anything tonight to diagnose the problem, so the lack of solution is neither surprising nor troubling.
Old 08-19-2014, 11:34 AM
quinletc's Avatar
A couple of questions regarding the sending unit, while I have it out.
1. There is some white oxidation on the parts of the unit that are inside the tank. Should I try to clean this off? What should I use?
2. I am tempted to hose the unit down with WD40, just on principle, as it is an electronic accessory that I can't access or see the insides of. Good idea? Bad idea? Makes no difference?
Old 08-19-2014, 11:58 AM
COAZ-9202-B (replaced B7A-9202-A & COAZ-9202-A) .. Fuel Sending Unit Float / Available from Ford ~ MSRP: $17.06.
Applications: 1957/79 Passenger Cars/Trucks / 1961/79 Econolines / 1966/79 Bronco's.
C1TF-9276-A .. In-Cab Fuel Tank Sending Unit Gasket / Available from Ford ~ MSRP: $5.83.
Applications: 1961/69 F100/1100 / 1970/77 F100/750.
Old 08-19-2014, 07:17 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
It's prolly just from additives added to the fuel. I'd just wipe them off with a rag.
Old 08-20-2014, 12:37 PM
quinletc's Avatar
Temp sending unit
OK, I've looked through my Shop Manuals and two different Chilton books I got from the library, and I can't seem to find a picture or description of WHERE the temperature sending unit is.
I think it's on top of the intake manifold, near the distributor, but I am not sure. And I don't want to go disconnecting or unscrewing things when I don't really know what they are. Anyone have a photo?
Oh, and this is on a 360.
Old 08-20-2014, 01:17 PM
It should be the only brass looking plug with a wire on it. It's right behind the distributor, on the manifold, pointing straight up.
Old 08-29-2014, 11:29 PM
quinletc's Avatar
For future reference, anyone replacing the temperature sending unit should be sure to drain the radiator below the level of the top of the intake manifold. Unless you enjoy making coolant geysers under the hood of your truck. They ARE a pretty green color.
Old 08-29-2014, 11:32 PM
^ Made that mistake before, haha
Fuel Gauge Reads Empty - Senders OK ? Birken Vogt 1987 - 1996 F150 & Larger F-Series Trucks 5 09-18-2016 08:35 PM
Alternator gauge 410 Highboy 1973 - 1979 F-100 & Larger F-Series Trucks 20 04-17-2014 02:41 PM
Gauges working intermittently iggybob44 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-30-2013 08:00 PM
Temperature guage replacement abeagle 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-12-2013 10:08 AM
Affects of bad cluster voltage regulator? Luch 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-07-2013 10:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
