Gas and Temperature Gauge Issues
on
The trick is to have your new one already to install and close at hand as you remove the old one pop the new one in with very little coolant lost..
Cheers
orich
on
But hey, I am still a live is all that counts!
And, I'm now old enough to know where dirt came from...
on
Thanks it' my ol money pit since 1978, the only things that have not been replaced is the hood & cab/frame. But my son will end up with it some day.
So don't care how much I put into as it gives me something to do.
And old farts need to keep busy or they'll die.
The paint is now 19 yrs old and now doing a little rust bubbles repair in the door jam areas.
Also going to replace the side trim with the 1.1\2" one and get it repainted as the hood is starting to peel clear coat..
Thanks again come back kid!
Orich
Orich
I have to use one of those plastic box crates to stand on to do any work on my engine, as it's a 4wd and I'm 6.1" with a bad back. So have to take my pain pills before doing any type of work on it leaning over..
I am 6'3" with a fair back, and it's a 2WD, but what with my ignorance, using a trouble-light in the dark, and the distributor being in the way, I was unprepared and unable to stem the green tide!
Testing gauges
You may have this fixed already but if you take the wire off the sending unit and put a 12 volt test light between the wire and ground the gauge should give a reading this will work for any of the gauges. If you get a reading it is the sender If you don't. There is a voltage regulator on the back of the gauge cluster if this is the problem all the gauges except the Amp meter. This regulator cuts the voltage from 12 volts to 5.
on
orich
oft
16
12-26-2014 09:08 PM
davidmoss1992
18
01-30-2012 12:03 AM
SGTFA
01-27-2003 11:01 PM
