Rough and Ready - Ford Truck Enthusiasts Forums
Rough and Ready
Old 06-27-2013, 12:10 AM
chetspencer's Avatar
chetspencer chetspencer is offline
chetspencer is gaining momentum as a positive member of FTE.
Rough and Ready
So after 15 plus years she's back on the road! I've only got to drive it for 5 minutes before all hell broke loose, but it was awesome.
Still hasn't had a decent bath, anyway the fuel pump died AND I had a short circuit to ground on the ammeter wires so I took this picture waiting for a tow. looking to get a new fuel pump but not sure if I should go with original or electric. Still has the original type generator and not sure if it could handle the extra load.
Old 06-27-2013, 10:32 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
Looking good. You've come a long ways with that truck nice work.
Old 06-27-2013, 12:49 PM
BroncoBundy BroncoBundy is offline
BroncoBundy is starting off with a positive reputation.
Carter P7040, very common and reliable. Run that with a cheap regulator and you are in business. Run it off a switch under the dash and it's an anti theft feature. Although you may want to install an inertia switch too in case of an accident if you are concerned about burning alive lol
Old 06-27-2013, 02:38 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Good to see another fridge 4x4 on the road.
Check your fuel tank for crud, incase your old pump died from crud ingestion.
Old 06-27-2013, 04:54 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
That thing looks great. Glad to see your progress. Definately clean the tank out as teddy mentioned.
Old 06-27-2013, 11:56 PM
Thanks for the feedback gentlemen. I'm happy to report that this is still a great County to live in as you can go to your local AutoZone and get a new original replacement fuel pump any day of the week for your ford y block. She's up and running again.
I really gave the battery a beating when the wires shorted, the ammeter was pegged at 30+ amp for awhile. Ill check the new in pump filter right away for junk but when I checked the old one before the test drive it looked good. Ill look at the old one again. I was thinking of buying a spare pump and stash it behing the seat along with a small tool kit. This truck has dual tanks with a somwhat hidden valve that could act as a theft deturant.
Speaking of theft , I'm already stressing a bit about that. Hope I can keep the wife content giving up her prime indoor parking spot.
Side question: was vinyl tape used back in 59 on the wiring harness?
Old 06-28-2013, 03:20 PM
spurredon's Avatar
Congrats on getting her rolling again. Yes, vinyl "wrap", was on the '59 harness.
Old 06-28-2013, 11:29 PM
So I got her registered today, got the licence plates cleaned up and illuminated, diagnosed that the low beam circuit breaker is refusing to pass a single electron.
Anyone know if the circuit breaker is self or manually reset? High Beams work fine.
1988 F-350 Build Thread BigBlockF350 1987 - 1996 F150 & Larger F-Series Trucks 433 12-29-2014 06:33 PM
Finally! i went to e fuel lablue96 1994.5 - 1997 7.3L Power Stroke Diesel 14 11-30-2013 11:54 PM
90 F250 Duel Tank Fuel Pump Problem Bigwrm 1987 - 1996 F150 & Larger F-Series Trucks 5 02-15-2011 10:28 PM
351m Not getting fuel. Help TheTech 1973 - 1979 F-100 & Larger F-Series Trucks 13 02-07-2011 08:55 PM
Power steering upgrade hav24wheel 1987 - 1996 F150 & Larger F-Series Trucks 16 06-08-2010 06:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
