1963 f-250 4x4 Roosevelt compound truck
Old 06-26-2013, 08:46 PM
htebazile's Avatar
htebazile
htebazile is offline
Newby here, i dont want to start out wanting help, But i need stuff and don't know where to turn,I have always cruised this, but never joined, well here i am the guy that never asks for help. The truck in question is very special, it came form the Roosevelt compound in New York, a special order 1963 f-250 4x4 Y-block with a documented 15,000 miles i have framed off and am now putting the final touches on her, the most needed item are rear drums, i know they dont grow on trees but with all the pros on this site i feel this is the place to be. i also am looking for a set of rear axle lock washers and a set of steel two piece rims. The list goes on and on, for now any help would make my life not suck. Thanks Kevin in Va.
Old 06-26-2013, 09:08 PM
schoo's Avatar
schoo
schoo is offline
With 15,000mi the drums should be turn able?
Unless damaged, mine have more than 78,000 mi and got them turned
Last edited by schoo; 06-26-2013 at 09:10 PM. Reason: The speedo has not worked in 28 years
Old 06-26-2013, 09:14 PM
htebazile's Avatar
htebazile
when i took them off the edges where chipped,i was very bummed, i can only asume a hammer got em. on a shade tree operation.
Old 06-26-2013, 09:22 PM
schoo's Avatar
schoo
schoo is offline
Napa had I can't remember either front or rear not sure and I'm in cali
And not much help but good luck
Would like see pix of truck
Old 06-26-2013, 09:30 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
If you are talking lock ring innie wheels Ill keep my eye out in our p&s yards here as Im stumbling over those alot of times Im there. Shipping from Washington state might kill your pocket book. Send me a pm I have something you may be interested in.
Old 06-26-2013, 11:14 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The truck in question is very special, it came from the Roosevelt compound in Hyde Park New York, a special order 1963 f-250 4x4 Y-block with a documented 15,000 miles.
The most needed item are rear drums and a set of rear axle lock washers.
Welcome to FTE
NAPA should have the lock washers and the drums. Take the Ford & Timken part numbers with you, as NAPA may be able to cross them over to the brands they sell.
If not, make sure the parts cluck looks in the paper parts catalogs (usually stashed under the counter). I doubt either will be listed on their computer.
1960/66 F250 4WD:
Ford: 61-1124 / Timken: 1229-Y-831 .. Lock Washer / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
FRIESEN FORD in Aurora NE has 2 = 402-694-3111.
NOS ONLY in San Jose CA has 4 = 800-667-6659.
3 other sources have 1 each.
COTT-1126-A .. Rear Brake Drum (does not come with the hub!) / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Blown 331
1999 to 2016 Super Duty
04-08-2013 09:02 PM
71sbf250
06-12-2009 07:48 AM
BrettCox
07-15-2004 01:30 AM
rearendwoes
12-07-2003 11:38 AM
Quick Reply: 1963 f-250 4x4 Roosevelt compound truck
