Gauges read high - Any solutions?
On the up note, my Pick & Pull cluster with factory tach was plug and play; tach fired right up on first try without having to change any wiring.
However, this "new" cluster reads even higher than the old one, specifically the temp and oil pressure gauges. Now they're just to the right of the last hash mark before the H. Before they were to the left of that hash mark, effectively putting the needle on the high side of "normal".
Is there anything that can be done about this? I suspect that little metal box on the back of the cluster has something to do with it, can this be replaced?
The fuel gauge has always been a little schizo, seems to work until you get down to half, but after that it's anyone's guess. Any help would be greatly appreciated.
Take the sending unit wires off and ground their wires and then unground their wires and see if the guage goes full scale up and down. If it does, I would suspect a grounding problem or a sending unit problem. Make sure you have a ground strap from one of the bellhousing bolts to the firewall.
Similar issue here with gauges reading high. I tried getting a new one but it worked worse than the old one. Gauges all over the place.
I think I'll try building one. Here's the step by step. I just ordered the part directly from Dimension Engineering but it hasn't come in yet... we'll see how it goes.
Ford Truck Enthusiasts Forums - Gary Lewis's Album: How To Build an ICVR Replacement
When the ICVR begins to fail, often times, one will notice either very low or high reading of all three affected gauges.
Brian Ski 44
19
05-31-2017 06:37 PM
clinte89
16
03-09-2015 07:11 PM
DreadyDiggs
04-30-2010 11:08 PM
jeff250
11-17-2004 03:36 PM
