1960 Turn Signal Wiring Schematic Needed - Horn Question too - Ford Truck Enthusiasts Forums
Old 06-26-2013, 04:35 PM
montego69 montego69 is offline
montego69 is starting off with a positive reputation.
Hi all,
Does anyone have a schematic for the wiring harness for the turn signal switch in my 1960 F100? I'm trying to match up the wires on my new Speedway Motors 20 circuit kit to the factory turn signal wires. It seems as though the wiring kit is GM based: It has a flat connector that I can tie into with the stock Ford wires. Just don't know for sure which wire color connects to which one in the kit.
For the horn, i'm also assuming that the wire in the kit's flat steering column connector needs to be pulled out and run through the firewall to where the horn wire comes through the steering box, correct?
Thanks all,
Nick in WI
Wiring Questions Gigemags05 1947 and Older Ford Trucks 4 11-19-2014 12:29 AM
Whats goin on here - turn signal/horn issue Old Brown Truck 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-13-2014 02:11 AM
Horn not working oft 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-17-2014 09:18 PM
1960 F100 HORN QUESTION NMcGee1960 1957 - 1960 F100 & Larger F-Series Trucks 15 08-25-2014 07:20 PM
Help with Horn Contact Duckmang 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-29-2013 12:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
