Spitting and Sputtering 69 360 Engine - Ford Truck Enthusiasts Forums
Old 06-26-2013, 10:23 AM
brobrad's Avatar
brobrad brobrad is offline
brobrad is starting off with a positive reputation.
I put a carb kit in my 67 F100 (which has a 69 360 engine). It was leaking etc, but running good until i put the kit in it. I did notice during the "adjustment" of the carburetor (which i have little experience with) that a coil/plug wire was shocking me each time i got close. I put new plug wires on yesterday thinking that would stop the spitting and sputtering. It helped, but did not stop it. I suppose a cracked distributor cap (though it appears to be fine) could be the cause. It idles fine, but spits and sputters when you try to accelerate. Another thought would be possible water in the fuel, but again, it wasn't doing that prior to this point. I cleaned the contact points on the points, but no cigar. Any suggestions much appreciated!!!
Old 06-27-2013, 12:47 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Hi!
1. to check for a hairline crack in the dist cap, spray a little WD40 on the inside of the cap...if it runs fine, it is either contamination or a hairline crack.
2. Yes, the plug wires could cause that as well...it is also not unusual to find a bad new wire as well....pull each plug wire as the engine is running to see if it is a specific plug/cylinder or if it varies...this will give some indication of where to look.
460 EFI spits and sputters case930diesel 1987 - 1996 F150 & Larger F-Series Trucks 3 05-24-2015 10:42 AM
can you help? jefrow03 1987 - 1996 F150 & Larger F-Series Trucks 19 03-11-2015 02:05 AM
pickup spits and sputters past 35 mph northdakota 67ford 1967 - 1972 F-100 & Larger F-Series Trucks 16 02-21-2015 11:18 PM
86 F150 Fuel pump issue gary oft 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-22-2014 08:37 PM
1986 F-150 302 with weird problem abennett69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 05-28-2009 08:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
