Decent Differential Shops in OKC Metro Area - Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
Old 06-26-2013, 01:05 AM
Yaga1973's Avatar
Yaga1973 Yaga1973 is offline
Elder User - What???
Yaga1973 is gaining momentum as a positive member of FTE.
Hey All,
I'm looking for a differential shop to install my gears and Trac-lok unit. I would do it all myself, but I don't have the necessary tools to do so and it would cost as much for me to buy them as it would to pay for the install. To be a little more specific, I'm swapping from 2.73s to 3.55s and adding the Trac-lok unit. My current rear end has nothing wrong with it (that I know of), so there shouldn't be any surprises.
So, with this in mind, are there any good differential shops in the OKC Metro area that don't charge an arm and a leg? Blumenthal's is a great shop, but very spendy. I've contacted a place between Norman and Tecumseh that wants $300 for an entire rebuild, I supply the parts, and they supply the labor and 2 year, 24,000 mile warranty. I also spoke with Gary's Differential and he quoted the same price with no warranty and I supply all the parts.
Are there any other shops or folks in the area that you guys would recommend?
Thank you,
Aaron
Old 06-26-2013, 08:00 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
If you don't find what you are looking for there maybe the guy that's done mine would do it. I realize its a hike up here, but maybe you could work it in with another reason to come to T-town.
Old 06-26-2013, 10:06 AM
Yaga1973's Avatar
I thought about asking you about your guy, Gary. I hope it doesn't come down to that as it is quite a drive, but distances haven't stopped me before, especially if something can be done the same day.
Old 06-26-2013, 10:12 AM
Gary Lewis's Avatar
He doesn't work that fast. In fact, he works at nights and on weekends as he has a day job.
Old 06-26-2013, 11:29 AM
Yaga1973's Avatar
How long did he have your differential?
Old 06-26-2013, 12:17 PM
Gary Lewis's Avatar
I'm thinking a week. But ask Jon Stittsworth as he's had one in much more recently.
Old 06-28-2013, 07:22 AM
jwtimme jwtimme is offline
jwtimme is gaining momentum as a positive member of FTE.
Axels transmition and transfers set up both the rear ends on the bronco for 125 each and he supplies the bearings he set up a couple 9" for 125 also but I supplied the parts then.
Old 06-28-2013, 07:23 AM
Axels transmition and transfers set up both the rear ends on the bronco for 125 each and he supplies the bearings he set up a couple 9" for 125 also but I supplied the parts then. That's if you wanted to make the trip to Tulsa.
+1 (918) 425-7725
3244 N Lewis Ave
Tulsa‎ Oklahoma‎ 74110
United States
Old 06-28-2013, 09:44 AM
Yaga1973's Avatar
Thank you for the recommendation, sir!
Old 08-14-2013, 07:06 PM
rogerf100's Avatar
rogerf100 rogerf100 is offline
rogerf100 is starting off with a positive reputation.
I used Gary's Differential Specialist in Moore once when I was building a 9 inch diff for my '55 F100. He was reasonable on price and fast turn around, but all I needed was new bearings installed. 405-794-0988, worth a call.
Old 08-20-2013, 02:40 PM
Yaga1973's Avatar
Thank you, Roger.
Old 01-30-2014, 04:59 PM
Yaga1973's Avatar
I ended up going with Gary's in Moore and I'm happy that I did. He charged me $300 labor with me supplying all of the parts to include fluids. His team did an excellent job rebuilding the entire differential to include setting up the new gearset and Trac-Loc. The rear end makes no noise and performs flawlessly.
So, if anyone in the OKC area needs a differential rebuilt/regeared, I recommend his services.
Old 01-30-2014, 05:05 PM
Gary Lewis's Avatar
Yaga? Where ya been?
Old 01-30-2014, 05:25 PM
Yaga1973's Avatar
Busy, busy, busy. From vacations to Florida, your typical holiday madness, and having fun with a 6 month old baby and a 2 1/2 year old toddler, I've been pretty darn busy.
Old 01-30-2014, 06:01 PM
Gary Lewis's Avatar
I can understand. We kept our two year-old grandtwins and discovered we run out of energy pretty quickly. And we aren't working!
Trac-lok axle swap axelgawn 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-04-2016 03:45 PM
Trac-Lok S-spring: Mustang vs. F-150 Yaga1973 1987 - 1996 F150 & Larger F-Series Trucks 12 07-02-2013 12:00 PM
What should labor cost on a delete and stud job? Shop in OKC? sparkkky 6.0L Power Stroke Diesel 6 04-03-2011 05:35 PM
Trac-Lok crazyredneckanyhow Offroad & 4x4 8 12-10-2007 11:37 AM
Ford 9" with Traction-Lok fordxxx Clutch, Transmission, Differential, Axle & Transfer Case 9 05-19-2006 03:37 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
