1970 ford f100 - Ford Truck Enthusiasts Forums
1970 ford f100
Old 06-25-2013, 08:25 PM
racing elvis racing elvis is offline
racing elvis is starting off with a positive reputation.
1970 ford f100
i have a 1970 f100 ford truck. i was wondering how can i lower the front end say up to 3 inches or so with out any real modifications?? change springs?? thanks,...bill
Old 08-11-2013, 11:39 PM
reaperauto1 reaperauto1 is offline
reaperauto1 is starting off with a positive reputation.
Best way to do that is to remove the springs, and cut one coil off at a time until you get the stance you want.
Old 10-05-2013, 06:27 AM
yetiman38237's Avatar
yetiman38237 yetiman38237 is offline
yetiman38237 is gaining momentum as a positive member of FTE.
I was wondering about cutting a coil off. Want to lower about 2" in front......while I have everything else laying in the floor why not?
Old 10-05-2013, 11:34 AM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
This isn't a Chevy so that's really, really bad advice.
Cutting coils may lower the front end but at the expense of negative camber, increased tire wear, and crummy handling.
Quote:
Read above.
Before cutting coils, determine how much suspension travel remains. The way to do that is to measure the distance btwn the I-beam and the bump stop.
Not very much, right? I figure between 2.0 and 2.75 inches, right?
Old 10-05-2013, 03:20 PM
Chevy has nothing to do with it. i lowered the same truck with the same method i described. He doesn't want to do major mods. Even if you use a complete lowering kit you will still need the allignment fixed on top of the $1000 kit. Cutting coils is free and effective and it only cost me $275 for new shocks and getting it realligned. two years and 22000 miles my tires have normal wear.
Old 10-05-2013, 05:20 PM
HIO Silver's Avatar
You neglected/ignored/forgot to state that a realignment to bend the stock beams to reduce the negative camber was required after cutting coils. Your post above made it sound like cutting coils was all that was required. Please be more thorough in your responses.
And how much wheel suspension travel remains? That's the distance btwn the top of the beams and the bump stop.
Old 10-05-2013, 05:21 PM
xkpsanit's Avatar
xkpsanit xkpsanit is offline
xkpsanit is gaining momentum as a positive member of FTE.
Wow, is this really happening. Get an education
Old 10-05-2013, 05:22 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
Twin I beam suspension , no cheap way to lower it correctly .
Yes you can cut coils but with no camber adjustment the tires will wear on the inside quickly .
Old 10-05-2013, 05:23 PM
HIO Silver's Avatar
Quote:
Scary, ain't it?
And I'm calling BS on lowering three inches simply by coil cutting and a beam bend.
Old 10-05-2013, 06:06 PM
Did we get invaded by Trolls ?
Old 10-05-2013, 07:58 PM
HIO Silver's Avatar
Quote:
Maybe. Likely from a C-10 forum or something.
Old 10-05-2013, 08:29 PM
Yea, I read some other threads and decided that is not what I want to do to my front end...
Old 10-05-2013, 09:23 PM
bradb2230 bradb2230 is offline
bradb2230 is starting off with a positive reputation.
lowering a front end with out modifications is like getting a peanut butter sandwich with out the bread...... both ways you end up with a mess.....
Old 10-06-2013, 10:50 AM
68fish 68fish is offline
68fish is starting off with a positive reputation.
Quote:
Thread winner, next subject.
Air Conditioning soulnamja 1967 - 1972 F-100 & Larger F-Series Trucks 27 07-08-2016 07:20 PM
Hello calif100 New Member Introductions 0 03-26-2015 01:21 AM
1970 dist. block parts needed. 70-360fe 1967 - 1972 F-100 & Larger F-Series Trucks 12 04-27-2014 12:36 PM
Looking For 1970 F100 Hood mike9602 New Member Introductions 1 10-15-2007 12:08 PM
1970 cruise control??? averagef250 1967 - 1972 F-100 & Larger F-Series Trucks 6 02-08-2005 07:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
