1970 ford f100
Old 06-25-2013, 07:25 PM
racing elvis's Avatar
racing elvis
racing elvis is offline
1970 ford f100
i have a 1970 f100 ford truck. i was wondering how can i lower the front end say up to 3 inches or so with out any real modifications?? change springs?? thanks,...bill
Old 08-11-2013, 10:39 PM
reaperauto1's Avatar
reaperauto1
reaperauto1 is offline
Best way to do that is to remove the springs, and cut one coil off at a time until you get the stance you want.
Old 10-05-2013, 05:27 AM
yetiman38237's Avatar
yetiman38237
yetiman38237 is offline
I was wondering about cutting a coil off. Want to lower about 2" in front......while I have everything else laying in the floor why not?
Old 10-05-2013, 10:34 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
This isn't a Chevy so that's really, really bad advice.
Cutting coils may lower the front end but at the expense of negative camber, increased tire wear, and crummy handling.
Read above.
Before cutting coils, determine how much suspension travel remains. The way to do that is to measure the distance btwn the I-beam and the bump stop.
Not very much, right? I figure between 2.0 and 2.75 inches, right?
Old 10-05-2013, 02:20 PM
reaperauto1
Chevy has nothing to do with it. i lowered the same truck with the same method i described. He doesn't want to do major mods. Even if you use a complete lowering kit you will still need the allignment fixed on top of the $1000 kit. Cutting coils is free and effective and it only cost me $275 for new shocks and getting it realligned. two years and 22000 miles my tires have normal wear.
Old 10-05-2013, 04:20 PM
HIO Silver's Avatar
HIO Silver
You neglected/ignored/forgot to state that a realignment to bend the stock beams to reduce the negative camber was required after cutting coils. Your post above made it sound like cutting coils was all that was required. Please be more thorough in your responses.
And how much wheel suspension travel remains? That's the distance btwn the top of the beams and the bump stop.
Old 10-05-2013, 04:21 PM
xkpsanit's Avatar
xkpsanit
xkpsanit is offline
Wow, is this really happening. Get an education
Old 10-05-2013, 04:22 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
Twin I beam suspension , no cheap way to lower it correctly .
Yes you can cut coils but with no camber adjustment the tires will wear on the inside quickly .
Old 10-05-2013, 04:23 PM
HIO Silver's Avatar
HIO Silver
Scary, ain't it?
And I'm calling BS on lowering three inches simply by coil cutting and a beam bend.
Old 10-05-2013, 05:06 PM
MIKES 68 F100
Did we get invaded by Trolls ?
Old 10-05-2013, 06:58 PM
HIO Silver's Avatar
HIO Silver
Maybe. Likely from a C-10 forum or something.
Old 10-05-2013, 07:29 PM
yetiman38237
Yea, I read some other threads and decided that is not what I want to do to my front end...
Old 10-05-2013, 08:23 PM
bradb2230's Avatar
bradb2230
bradb2230 is offline
lowering a front end with out modifications is like getting a peanut butter sandwich with out the bread...... both ways you end up with a mess.....
Old 10-06-2013, 09:50 AM
68fish's Avatar
68fish
68fish is offline
Thread winner, next subject.
japrine
16
01-30-2024 03:25 PM
nick01psd
07-31-2013 06:22 PM
overlandexpress
22
12-03-2009 10:50 AM
moore89
06-03-2003 10:11 PM
Josef Girouard
07-05-2000 03:42 PM
Quick Reply: 1970 ford f100
