Adjusting My Temp Guage
Has anybody used a resister to fine tune your temperature guage? My Y-Block has a 180* thermostate installed in place of the stock 160* unit and the result is that the temp guage reads at about 90 percent hot. This bothers me because people (wife) think that the engine is running too hot. My plan is to intall a resister between the temp sender and the guage to reduce the reading. I'm just curious about the amount of ohms reduction necessary. 20? 40? Any help would be appreciated to help me avoid buying a whole assortment of resisters. Jag
A resistor won't really work well. The gauges don't work on pure voltage. The temp sender sends pulses more or less frequently based on temperature. Are you running 12v with a CVR?
You can (at least on BonusBuilts) adjust the temp gauge thru a little window on the back of the gauge. It is covered by a little circle of paper or tape. It's like an old watch adjustment, a toothed wheel you turn a little to fine-tune the reading.
I'm still 6-volt +ground on the 55 Fairlane. I've had the guage out a few years ago and don't recall seeing anything like a cover or hole in the back. That would be nice if there would have been one.
I thought that the sender just provided a ground that increased conductivity as the water temp rose.
I know on my 48 the temp gauge is somewhat counter intuitive from what you might think. If the gauge goes to hot with the switch turned off then inserting a resistor in series would actually make it read hotter. If this is the case you could try putting a resistor in parallel with the sending unit and tweak it down a little bit.
Yea, the 160* is the stock temp. I run the 180* because I believe that the engine runs better.
The sender has already been replaced last year in the attempt of getting it to read right. There was no effect for my $50 I also exchanged the gauge about that time with another used unit that I had. Again, no effect noticed.
My 55 car guage is normally all the way to the hot side when the key is off. When you start the car it stays on hot for about 2 minutes and then slowly progresses all the way to the cold side and eventually returns to the 90 percent hot reading.
So do you think the addition of a resister will actually make it read even hotter? I'll check the spare guage again for any adjustment hole on the back. Jag
Guestimating that the resistor will effectively see 6 V, or 12 V at 50% duty cycle, a 10 Ohm resistor will dissapate an average of 3.6 Watts. To prevent catastrophic resistor failure, one usually designs in a 2/1 safety factor. In other words, that 10 Ohm resistor should be rated at 8 to 10 Watts.
If it were mine, I'd calculate worst case (12 V continuous) or, actually, I'd pull the gauge and adjust the star mechanism. My 2c
