What do you guys make of this crew cab on Vegas CL????
Old 06-25-2013, 10:49 AM
RocketMonkey28's Avatar
RocketMonkey28
RocketMonkey28 is offline
1963 ford crew cab body
Old 06-25-2013, 10:56 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Is it a 1963?
Has a 1966 grille, 1965/66 upper grille panel, bumper bolts to frame horns using 2 bolts per side.
1961/63: Front bumper bolts to frame horns using 3 bolts per side in a triangular pattern.
1961/64 and early 1965 crews were outside conversions, many done by Crown Coach...have exposed rear door hinges.
Mid-year 1965, FoMoCo began assembling their own crews for the first time, rear door hinges are not exposed.
Dave (garbz2) is the Crew Cab guru.
Old 06-25-2013, 11:16 AM
RocketMonkey28
The doors are far more interesting than the cobbled bits in the front. I noticed the hidden hinges and the shape of the vent/wing window. You think this may be a factory cab? How about the floor in front with the footwell/sill recesses?
Old 06-25-2013, 11:41 AM
NumberDummy
No cab step: 1965/66 F100/250 2WD & 1966 F100 4WD
Old 06-25-2013, 01:08 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Inside stepwell was used from 61-66 on large trucks and F250 4wd. 61-65
F100 4wd. Also used on F100 and F250 2wd 61-64. Bill spelled out for you were they were not used. Looking at the interior the cab looks to have a pre 65 heater box that was used from 61-64. Later model got a different heater assembly.
Old 06-25-2013, 03:51 PM
Customcab's Avatar
Customcab
Customcab is offline
As the ad mention sounds like a put together project; looks good; price?
Old 06-25-2013, 06:13 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
More than I would pay for just the body, but I'm pretty cheap. Would pay that for the whole truck....what an awesome hauler!
Old 06-25-2013, 07:31 PM
gangstakr's Avatar
gangstakr
gangstakr is offline
This looks like the front door and it has the step like 61-64, from what I've seen, the 65-66 crews have flat floors in front with the step at the rear doors.
<section class="userbody"> <figure class="iw">
</figure></section>
Old 06-25-2013, 07:41 PM
stoffer's Avatar
stoffer
stoffer is offline
I like the lack of pictures on the underside and lack of engine bay pictures
Old 06-25-2013, 08:45 PM
NumberDummy
Cab step: 1961/64 F100/1100 / 1965 F100/250 4WD / 1965/66 F350/1100 / 1966 F250 4WD
No cab step: 1965/66 F100/250 2WD / 1966 F100 4WD
Old 06-27-2013, 02:08 AM
garbz2's Avatar
garbz2
garbz2 is offline
Pre 65 cab.
Easy to tell as it has the oval fresh air vent on the passenger kick panel.
65 switched to a passenger side triangular manual door and round fresh air inlet above on 2 wheel drive, 4x4 cabs and F350s
Also looking at the cab floor and the rear doors this is a one off conversion possibly done with 2 full cabs back in 1980. The wing window looks to be from a mid 50s. truck.
It is not a crown or any other aftermarket style i have seen.
it would be a good grab for anyone in that area.
Garbz
Old 06-27-2013, 05:23 AM
jowilker's Avatar
jowilker
jowilker is offline
Not to argue but photos can make things look different than what they are sometimes.
John
Walston
08-10-2017 09:04 PM
techr4life
36
08-13-2014 12:33 PM
Ol'Blue ford
08-07-2013 06:33 PM
69supercj
13
07-04-2013 10:49 PM
Krim
06-08-2009 01:36 AM
Quick Reply: What do you guys make of this crew cab on Vegas CL????
