Cruise control problems
Old 06-24-2013, 01:10 PM
Furniture Doctor's Avatar
Furniture Doctor
Furniture Doctor is offline
I have a 1996 PSD with a E4OD Tranny. The cruise control quit working and I am trying to figure out what is wrong. The truck does not have an airbag- does this mean there is no clock spring under the steering wheel cover? I did not see any screw holes that would the steering wheel cover to be removed. How does this come off? Where would the CC sensor module be located? I would appreciate any helpful ideas.
Doc
Old 06-24-2013, 03:14 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Check the fuse for the cruise, and also make sure all your brake lights are working, especially the third light up on the back of the cab. The steering wheel cover just pulls off. Just get a hold of it and pull it straight back toward you.
Old 06-24-2013, 06:59 PM
madpogue's Avatar
madpogue
madpogue is offline
The "sensor" is the PCM. It simply keeps a constant check on the speed, and adjusts the fuel accordingly.
Is this a van?
Old 06-24-2013, 07:43 PM
Furniture Doctor
Cruise control
This a F250 4X4.
Old 06-24-2013, 07:44 PM
nomad221's Avatar
nomad221
nomad221 is offline
Have you had the CC recall done ?
Old 06-24-2013, 08:20 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Does your horn work? My 96's cruise quit and I found the fuse for the horn blown and the cruise started working again.
Old 06-24-2013, 08:45 PM
madpogue's Avatar
madpogue
madpogue is offline
Then there's no air bag. The "clockspring" is just a set of contact rings. Possible it's at fault, but the switch on the master cylinder is a prime suspect (cf. the "cc recall" comment above).
Old 06-24-2013, 09:35 PM
59JEEPSTANG's Avatar
59JEEPSTANG
59JEEPSTANG is offline
X 2 on the switch located on the master cylinder (that the recall harness attaches to).
Paul
Old 06-24-2013, 11:13 PM
nomad221's Avatar
nomad221
nomad221 is offline
Ya, I don't wanna read about anymore engine compartment fires.
Old 06-24-2013, 11:22 PM
oldbird1965
Read about it Greg? There was a picture around here that will get your attention! LOL
Old 06-25-2013, 07:44 PM
Furniture Doctor
Cruise Control
I did take the truck to the local Ford dealer and had the piece changed on the master cylinder. The horn does work. I don't know about the third light since I work by myself. I still need to check the fuses.
Doc
Old 06-25-2013, 08:20 PM
oldbird1965
I use a sledge hammer or big bar to push the brake pedal down to see the brake lights.
Old 06-26-2013, 12:19 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Lightbulb
Or a scrap piece of wood.
Old 06-26-2013, 02:11 PM
oldbird1965
haha, that's right! Anything that's the right length up against the seat or back of the steering wheel to hold the pedal down. I personally got tired of asking my wife for help. She would say, 'just a minute'. An hour later she comes out, LOL.
1986F-150
1999 to 2016 Super Duty
11-28-2017 02:54 PM
trucktech
01-07-2012 07:27 AM
tlc3810
08-26-2011 02:10 PM
dakota-boy
Electrical Systems/Wiring
05-08-2009 01:34 PM
RandB
Aerostar
07-11-2007 11:07 PM
Quick Reply: Cruise control problems
