A/C gets warm while at idle - Ford Truck Enthusiasts Forums
Old 06-25-2013, 09:49 AM
LSO1123 LSO1123 is offline
LSO1123 is gaining momentum as a positive member of FTE.
Hey guys,
As it got warm this summer and I started using the A/C in my truck I've noticed that if the truck sets at idle for longer than just a minute or two, the A/C will start blowing warm air, not like heat or anything, just not cold. As long as I'm driving it blows nice and cold. It also takes longer than it should to start blowing cold air when I first start the truck and drive somewhere. I've checked the freon and it's good. Is the compressor getting weak or could it be another issue?
Old 06-25-2013, 10:01 AM
grec-o-face's Avatar
grec-o-face grec-o-face is offline
grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.
Have you checked the Compressor Gap, per SpringerPop's write-up?
SpringerPop's Compressor Clutch Air Gap
Old 06-25-2013, 10:23 AM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
Check compressor gap. See what your psis are. Also, make sure there are no weeds etc in radiator and condensor area. However, its not uncommon for the a.c to blow slightly warmer at idle than at other speeds.
Old 06-25-2013, 10:40 AM
Thanks for the advise guys, I'd never heard of compressor air gap before so I'll check that. As far as the PSI goes, what should it be? The radiator and condenser area is probably due to be cleaned out so I'll do that also. It's not just slightly warmer, It's alot warmer like if you turned the switch to just fan and not A/C.
Old 06-25-2013, 12:23 PM
Sounds like gap or low freon
Old 06-25-2013, 12:25 PM
cutlass's Avatar
cutlass cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
Yes, low freon is another possible cause here.
Drake
Old 06-26-2013, 11:47 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
My truck was doing the same thing. Roland and I took the shim out of the clutch this last Saturday and that fixed it. Takes about 5 mins to do this if you take your time.
Old 06-26-2013, 08:58 PM
petrokiller's Avatar
petrokiller petrokiller is offline
petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.
Yes pull the shim off the Compressor. It fixed mine up great.
Just be slow win pulling the front plate off so shim doesn't drop. Think its like a 10 mm socket and 2 small screwdrivers. 5 mins.
Old 06-26-2013, 09:30 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Actually, it is a 8 mm on the clutch shoe retaining bolt.
Old 06-26-2013, 10:23 PM
Thank you for the correction
Old 06-27-2013, 05:01 AM
TchTchr TchTchr is offline
TchTchr is starting off with a positive reputation.
I learn something new on here all the time - thanks!
Page saved for future reference.
Old 06-28-2013, 03:47 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
I began to experience the same thing when my alternator started going out. The low RPM simply could not keep the appropriate level of charge going. I would try the compressor shim first, and if that doesn't take care of the problem, then have your alternator checked.
A/C blowing cold but belt squealing pba369 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 07-12-2016 07:37 PM
Cold Ac when Idle and Hot when driving? Any Ideas partslady 1999 to 2016 Super Duty 2 05-14-2014 12:31 PM
2002 navigator rear a/c blows cold then warm jeffrey5679 1997-2006 Expedition & Navigator 2 05-08-2013 09:29 AM
a/c clutch rpbfixit 1999 to 2016 Super Duty 3 07-30-2012 11:20 AM
a/c gets warmer/musty in traffic raineytx Excursion - King of SUVs 14 08-08-2005 10:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
