Would you stay away from purchasing this truck? (Transfer case problems) - Ford Truck Enthusiasts Forums
Old 06-25-2013, 03:53 AM
MichiganMikey MichiganMikey is offline
MichiganMikey is starting off with a positive reputation.
I am new here and do not own a ford yet but have been in the market for one. I found a 2006 F-150 Harley Davidson Edition 4x4. It has 63k miles on it and is in near perfect condition, except for one problem. The seller has removed the front drive shaft due to noise coming from the transfer case. This is what he stated in his advertisement:
"I have the front drive shaft taken off the truck so it is only 2WD (Rear) at the moment. It is perfectly safe and drivable without the front drive shaft on. I have been driving it for about a year like this. If I put the Front drive shaft on it feels like either the front Differential Ring & Pinion Gear is worn and has bad contact or the Transfer case chain is loose causing it to skip. The engine, Transmission, and other drivetrain parts are perfectly fine. Don't let this small issue deter you from an excellent buying opportunity."
I have heard that this could possibly be a common problem with this year model truck and maybe a bad solenoid or sensor replacement would fix it. Worst case scenario, it needs a new or rebuilt transfer case, anyone have a ballpark estimate what that would cost? Would you stay away from this truck with this problem? It is priced about $6k below book value and seems to be a pretty good deal to me. What say you? Thanks in advance for any input. Cheers!
Old 06-25-2013, 06:46 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
About this much;
2006 FORD F-150 Parts - TascaParts.com
Plus labor.
It's always buyer beware... Have the truck checked out by a mechanic.
Old 06-25-2013, 01:18 PM
skunkoffroad skunkoffroad is offline
skunkoffroad is starting off with a positive reputation.
It might be a IWE issue do a search, read up, then go look at it.
Old 06-25-2013, 03:28 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
I second the possible IWE problem. I haven't seen many transfer case or front diff failures. One of the hubs could be leaking vacuum and the resulting grinding noise is mistaken for a transfer case problem.
Old 06-25-2013, 04:30 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by 60DRB View Post
About this much;
Plus labor.
Just FYI, the two posts you made where you linked to Tasca Ford don't show any parts, just the front search page for Tasca Ford parts.
Stewart
Pinion Shaft Stuck Auctioneer NJ 1987 - 1996 F150 & Larger F-Series Trucks 17 10-17-2014 09:46 AM
2004 Ford Ranger 4wheel drive Vibration at 40mph p61sam Ranger & B-Series 2 07-01-2014 10:00 PM
99 Transfer Case Question Macs1964F100 1999 - 2003 7.3L Power Stroke Diesel 2 02-17-2014 10:46 AM
99 Expy shift motor socket does not line up with transfer case shaft vtgboss Expedition & Navigator 27 12-18-2013 01:22 PM
Transfer case / Hubs / Diff / Vacuum confusion Enduroman 6.0L Power Stroke Diesel 17 12-06-2013 03:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
