fuel leak - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
fuel leak
Old 06-25-2013, 12:16 AM
mudrat025 mudrat025 is offline
mudrat025 is starting off with a positive reputation.
fuel leak
hello, i have a new fuel leak!first it was the fuel filter cap cracked. replaced that and gasket then still leaking,see fuel sensor leaking after warmed up (swelling).bypassed it nut still leaking!!!can anyone tell me where else these engines have problems before i just throw in the towel and go to mechanic???
Old 06-25-2013, 02:38 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Dont give up yet. We can get you all fixed up. Fuel is know to leak on these in various places in the valley. Try to get the already leaked fuel cleaned up and then start it and watch for leaks. If its the fuel restriction sensor leaking, it can be taken out and replaced with a plug. Check the lines from the pump to the bowl. They can crack and start leaking. If you have alot of miles on it, its probably a good idea to take the fuel bowl out and replace the orings. All these parts can be bought at riff raff diesel.com or diesel orings.com.
Old 06-26-2013, 01:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Lightbulb
Quote:
Yeap dont give up. Other sources of leak is the fuel pump and the rotted bottom of the fuel bowl itself, as in my case, I used JW weld and fixed that.
Also agree about to take the fuel bowl out and....
Old 06-26-2013, 03:55 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Can also leak out of the back of the heads and front of the heads but if your valley is full its probably one of the above suggestions.
Old 06-27-2013, 08:23 PM
well the filter lid and o rings were replaced when i first saw the leak and the fuel restriction sensor was plugged at the same time. so today i replaced all the rubber hoses but i am wondering how to purge the fuel system since everything drained out?
Old 06-27-2013, 08:49 PM
Fill the bowl up and fire it up.
Old 06-27-2013, 09:06 PM
okay thanks
fuel leak??? BrendanT7 1994.5 - 1997 7.3L Power Stroke Diesel 5 12-10-2012 08:04 PM
fuel bowl leak jkidd_39 1999 - 2003 7.3L Power Stroke Diesel 5 08-03-2012 01:55 PM
Fuel Pump Vacuum Leak nanuke1 6.0L Power Stroke Diesel 10 04-09-2012 04:59 PM
Leak out of fuel/water seperator Chuck88 1999 to 2016 Super Duty 6 10-21-2007 09:56 PM
leaking fuel from behind fuel pump redtantrix 1999 - 2003 7.3L Power Stroke Diesel 0 10-13-2003 08:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
