Collapsed Lifter ??? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-24-2013, 10:33 PM
ezjtdoc ezjtdoc is offline
ezjtdoc is starting off with a positive reputation.
97' 7.3 turbo diesel /Took the passenger side valve cover off, and one of the intake rocker arms is broken. Now the push rod falls to far into the head,very far in. Is this a collapsed lifter ?
Old 06-24-2013, 11:12 PM
cparks cparks is offline
cparks is starting off with a positive reputation.
Most likely not, the lifter was probably knocked out of the hole by the camshaft when the rocker arm broke. Going to need to try and get it back in the hole.
Old 06-25-2013, 04:11 AM
That makes it all perfectly clear,the rods falling right to the cam lobe.
Old 06-25-2013, 06:23 AM
glruff's Avatar
glruff glruff is online now
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
Moved to tech forum.
Old 06-25-2013, 07:26 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Is the lifter sitting under the valve cover in there somewhere? If not, and you need one send me a PM, I have a bunch of them laying around and assuming I can find a good one, you can have it if you will pay the shipping. I may be able to find a pushrod for you too, but I think you're on your own for the lifter, lol.
Old 06-25-2013, 02:13 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
i'm curious, is it possible to replace a lifter with just the valve cover removed. I thought the shop manual says you have to pull the engine and do the work from below with the oil pan removed. that is if i'm correct in translating their term 'valve tappet' to what everyone else calls a lifter...
it would make sense that you could just drop it in from above, though. getting an old one out from above may be tricky/impossible, though, I suppose...
Old 06-25-2013, 06:24 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Not possible without head removal.the lifter cant come out of the bore unless lifter retainer plate is broke...at wich point there is all kinds of bad $hisk messed up and the engine is coming out for sure cause its broke!
Old 06-25-2013, 08:17 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Make sure the end of the push rod didn't break off.
Old 06-26-2013, 04:14 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
Its cool that you move it to the tech forum but don't close it here. This is interesting but sounds like Aaron nailed it. Tried to rep but....
I also have a bunch of push rods.
Old 06-26-2013, 11:54 PM
fordman67's Avatar
Just if he looks down at the lifter and its out of the bore completly...that's real bad.I have seen when the lifter retainer brakes and the roller lifter turns.its ugly.
Its funny how these reps will for some yet not for others.fishy,butwe won't go down that road again.
Old 06-27-2013, 12:01 AM
Lets just say, its the thought that counts, LOL!
Old 06-27-2013, 12:03 AM
fordman67's Avatar
Yes sir!and thank you! I hope all is well there on the road.
Old 06-27-2013, 12:10 AM
So far, so good Aaron. Grandkids are keeping me busy and sat. we leave for Michigan.
Old 06-27-2013, 12:17 AM
fordman67's Avatar
Then rre afterward lol
Old 06-27-2013, 12:34 AM
I wish I could!
Lifter help Oldschool2888 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 07-22-2016 01:23 AM
lifter troubles normalmike 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-07-2013 12:48 AM
Lifter Collapse ? Crazy-Horse-Power!! 6.0L Power Stroke Diesel 8 08-24-2012 07:14 PM
Collapsed Lifters? Otahyoni Ranger & B-Series 6 08-04-2011 07:26 PM
collapsed lifter?? Cheshire Cat 1966 - 1977 Early Broncos 10 01-26-2008 12:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
