Need info on 1958 M100 Vin - Ford Truck Enthusiasts Forums
Old 06-24-2013, 06:09 PM
nfstyl nfstyl is offline
nfstyl is starting off with a positive reputation.
My uncle, father and I are trying to gather as much info as we can about the truck, (it was my grandfathers and we are planning to restore) right now the catch is my uncle can't find the vin.
Through some detective work I've managed to find a number on the glove box plate, I think I've decoded most of it, I'm hoping its right..
Number is 5991010WK12774
If what I've done is right the info goes like this
5 ?
99- Styleside
10-M100
10-110 Wheelbase
W-Build year
K-Oakville Plant
12774- Sequence number.
So, I'm wondering if the vin actually starts with a M10 or a F10. I would think F10 so, the vin should be
F10*8K12774
The star would be engine size right ? Which is what the 5 at the start of the number should be ?
Anyone have any ideas ?? How far off am I ?
Thanks.
Old 06-24-2013, 08:30 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
That's an interest number you have come up with. The NumberDummy will be your best bet for explanation. Post all the info you can find.
Old 06-24-2013, 10:00 PM
Sadly, that's all the info I have here.
The truck is 3 hours away from where I am.
What I have is what was on the data plate on the glove box door.
5991010WK12774
AGD
99
3 LD
4.11-1
M100
110
5000
The info I have seen says that AGD is Trim package
99 is Paint which I've found to be Burgundy
3LD is 3 speed Light Duty Trans
4.11-1 seems to be Gear Ratio
M100 is model
110 is wheelbase
5000 is GVW
I've been told it is a 6 cyl, and my research says that the only 6 was there is a 272 CI 2 Barrel Carb with 153 Horsepower
So I'm hoping that my hours jumping from fan page to fan page is accurate and that what I've seen here so far actually pans out the way I'd like it to.
Old 06-24-2013, 10:40 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
There are several Mercury owners on here and the 49-56 forum that may have info to help decode. But I don't think the Ford info translate to Mercury.
New Vin plate from Marti Auto Works Oz Econoline 1973 - 1979 F-100 & Larger F-Series Trucks 33 06-25-2016 01:36 PM
Just a quick intro of DSC DallasSuperCrew 2004 - 2008 F150 6 05-30-2016 10:13 PM
Vin number 82fordowner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 10-30-2015 06:33 PM
Short truck step placement help Luch 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-17-2013 06:59 PM
Block Casting Numbers for a 262 oldjoe 1961 - 1966 F-100 & Larger F-Series Trucks 7 11-27-2010 04:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
