Fuse box !!HELP!!
Old 06-24-2013, 04:09 PM
ddowell1's Avatar
ddowell1
ddowell1 is offline
Fuse box !!HELP!!
so guys I am trying to hook up my new tachometer, however the letters on my fuse box are unreadeable. so I was wondering if anyone had a diagram, or a picture of a fuse box in a 1977 f250 custom that shows what kind of fuses are used and what they control
Old 06-24-2013, 05:04 PM
jim collins's Avatar
jim collins
jim collins is offline
I thought they hooked up at the coil. My 79s coil has a terminal marked ' tach' .That's where i hooked up one on a street rod i have.
Old 06-24-2013, 05:25 PM
V10man's Avatar
V10man
V10man is offline
He still needs + power for the tach. I would use a test light to see what is hot with the key on. Should have my tach in this week.
Old 06-24-2013, 06:38 PM
TexasTrash's Avatar
TexasTrash
TexasTrash is offline
Old 06-24-2013, 06:45 PM
OrangeBeast's Avatar
OrangeBeast
OrangeBeast is offline
Here is a scan I posted in another thread. It is from my owners manual for my 77 Custom if your box doesn't match up to the other post:
https://www.ford-trucks.com/forums/1...l#post13171862
Old 06-24-2013, 10:07 PM
teds74ford's Avatar
teds74ford
teds74ford is offline
Even easier:
Keyed power behind instruments
Lights are blue/red
Of course you need a tach lead and a ground
If you use these things, you don't need to cut at all, just crimp on some ring terminals and bullet connectors.
Old 06-24-2013, 10:14 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Btw when using bullet connectors, the female side is used on the hot or energized side and the male end is downstream.
Why? Because an energized and open male bullet connector can short to ground if left unconnected. Bzzzzt.
Old 06-27-2013, 10:58 AM
ddowell1's Avatar
ddowell1
ddowell1 is offline
thanks for all the help! got the tach in and working good!
Macs1964F100
13
07-11-2014 11:21 AM
AbandonedBronco
32
11-26-2012 12:26 PM
newrider3
15
03-26-2010 09:58 AM
Quick Reply: Fuse box !!HELP!!
