Need help - brake measurement - Ford Truck Enthusiasts Forums
Old 06-24-2013, 04:32 PM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
I have a dana 60 from a 59 F250 that I am putting in my 49 F3. I couldn't get brake drums in Australia so with the help of a friend got a set at NAPA in the US. Problem is they measure 2.5" across the friction surface, the brake pads are only 2". Is this right? Can someone please measure a drum and let me know before I spend a fortune shipping the wrong drums to Aus.
Thanks.
Old 06-24-2013, 08:44 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
The manual does call out for the width of the brake linings to be 2" for front and rear for the F-250 1960. The brake drum spec. is only listed as diameter, which is 12 1/8". Not sure of the depth. The manual does state that the F-350 uses 2 1/2" wide brake linings with 13 inch diameter drums. Sounds like your brake drums you found may be for a F-350 with a larger diameter backing plate.
Old 06-24-2013, 09:13 PM
The diameter is correct at 12 1/8" so I don't think they are F-350 drums.
Drum sizes for 78 F150 hermancm 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-24-2014 07:41 AM
Help - need measurements aussiecowboy 1961 - 1966 F-100 & Larger F-Series Trucks 0 01-13-2013 05:25 AM
rear drum size? 1980 F150 1980302windsor 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-31-2011 02:22 AM
1950 F-3 front brake drums Christopher2 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-13-2004 10:53 PM
59 F250 Front Brake Drums 59 F250 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-23-2004 12:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
