EFI v8 swap - Ford Truck Enthusiasts Forums
EFI v8 swap
Old 06-24-2013, 03:55 PM
fordf350camper's Avatar
fordf350camper fordf350camper is offline
fordf350camper is starting off with a positive reputation.
EFI v8 swap
Hi i am trying to find out as much as possible fitting a ford efi v8 engine out of a econoline E150 1989 with od in my truck.I am not sure were to ask so i thought i would try here but welcome you to give me advice.I am want to find out is the a stand alone ecu that could be brought for this engine if so who who sell one.Is this engine the same as the 302 mustang will the mustang engine parts fit the engine i have as all i have been doing is google ford econoline parts.Also can i make my gearbox floor change i think its a C6 with od.Thank you
Old 06-26-2013, 01:53 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
this is a very popular swap not only for these trucks but a whole range of classic Fords. lots of articles on the internet on how to do it. lots of aftermarket wiring kits available to do this also. i would check sites like Jegs, Summit, Painless Wiring and Ford Racing to see what they offer. you can use the stock computer and wiring harness from the van but you would need a wiring diagram to figure out what wires to use and not to use. my opinion you are better off using an aftermarket ecu and wiring harness as they usually come with simplified wiring and instructions of how to hook it up and the ecu are usually programmable. you will also need to upgrade the fuel system to a hi pressure unit with return line.
the mustang engine is the same but different. uses a better intake and injector setup along with a better cam and factory headers. but there is such a huge aftermarket for these EFI 302/5.0 engines that i wouldn't be to worried about where i got the engine out of. you can make some decent power with the right selection of parts.
good luck
Mike
Old 06-26-2013, 02:21 PM
BroncoBundy BroncoBundy is offline
BroncoBundy is starting off with a positive reputation.
I am in the middle of collecting a Mustang EFI setup for my 68' Bronco. You can use Explorer parts as well and Ron Francis makes a killer harness that you can have them switch the sensor plugs to explorer or mustang, whichever you plan to use. Mustang setup and ECU is the most popular route as the explorer harness is OBDII.
Here are some good links on 302 EFI
RJM Injection Tech — RJM 5.0L EFI Harness Compatibility List
http://oldfuelinjection.com/
and this one that is more Bronco specific but still very relevant.
http://oldfuelinjection.com/Inject_your_horse1.pdf
http://oldfuelinjection.com/Inject_your_horse2.pdf
http://oldfuelinjection.com/Inject_your_horse3.pdf
Econoline wanted Oz Econoline S. California Chapter 1 01-05-2016 12:15 AM
4 Banger Econoline Anyone? FancyFlush Ranchero & 1961 - 1967 Econoline 2 07-14-2014 12:21 PM
Im starting a new project. MonsterPool Ranchero & 1961 - 1967 Econoline 2 02-09-2014 11:48 PM
New guy with new project in Iowa 4x4slik New Member Introductions 5 01-24-2014 11:06 AM
1978 F250 Econoline Luddy 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-18-2011 10:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
