GT3782VA rebuild kit part number - Ford Truck Enthusiasts Forums
Old 06-24-2013, 03:32 PM
blowin_smoke_1977's Avatar
blowin_smoke_1977 blowin_smoke_1977 is offline
blowin_smoke_1977 is starting off with a positive reputation.
Anyone know the part number and source for a Garrett GT3782VA (2004.5-2007) turbo rebuild kit?
Old 06-24-2013, 07:12 PM
2003 EXCURSION 2003 EXCURSION is offline
2003 EXCURSION is gaining momentum as a positive member of FTE.2003 EXCURSION is gaining momentum as a positive member of FTE.
There is a pretty good recent thread on another forum which may be helpful here. It includes a couple of good links as well. Turbo cleaning kit and procedure? - Diesel Forum - TheDieselStop.com
Good luck, Mike
Old 06-24-2013, 08:01 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
On the box in the first couple of pictures.
Rebuilding the 6.0 VGTurbo - Ford Truck Enthusiasts Forums
Old 06-25-2013, 12:25 AM
daddykitty's Avatar
daddykitty daddykitty is offline
daddykitty is gaining momentum as a positive member of FTE.daddykitty is gaining momentum as a positive member of FTE.
Old 06-25-2013, 02:21 AM
Thanks kitty. Bought and on the way.
I just wanted to make sure I had the right kit. Apparently there were two turbos for the 6.0, and each uses slightly different bushing sizes.
Old 06-25-2013, 12:32 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
you've just about rebuilt the whole truck??
Did it Not build BOOST??
Blown Oil threw it??
Old 06-25-2013, 02:46 PM
Turbo question: I assume that most who rebuild their turbo are doing it because of a known problem. Are there many who do this simply because they are fairly aggressive about preventative maintenance?? Is that a good idea at some point? Thanks!
Old 06-25-2013, 04:16 PM
Blades it is leaking oil past the turbo seals. It has that ominous blue-white cloud of smoke at start-up similar to a radial engine. Its getting bad enough now that you can see faint traces of smoke while parked or at a stop light, and its only going to get worse as time goes on. After all of this, the last thing I need is a run-away. It has been doing this since the head gasket and stud install. The EBP sensor got clogged up with grime and caused the turbo to produce about 60 pounds of boost upon acceleration which compromised the seals. Oh the drama of computer controlled powertrains.
Old 06-25-2013, 06:07 PM
davidkstyler's Avatar
davidkstyler davidkstyler is offline
davidkstyler has a good reputation on FTE.davidkstyler has a good reputation on FTE.
Quote:
Most do it because of a problem. I had my turbo off to replace the EGR cooler and oil cooler. The truck had 160k and it seemed like a good idea to check it while off the engine. If your engine has not been worked, or has idled a lot, the turbo can coke up and stick. Mine was in good shape, the bearings felt good and just a light coat of carbon on the vanes and case. They make cleaning kits or if its just light carbon you can use a soft wire brush and reassemble with anti-seize grease. There are procedures in the Tech Folder.
http://www.ford-trucks.com/forums/83...urbo-abcs.html
Old 06-25-2013, 06:31 PM
Thanks David!
Old 06-26-2013, 01:02 AM
daddykitty's Avatar
Plus its much cheaper to rebuild it than buy a new one
Doing injector o-rings, anything I'm forgetting? WatsonR 6.0L Power Stroke Diesel 18 06-06-2016 04:23 PM
Cowl seal hturner12 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 10-16-2015 10:01 PM
1994 Ford F150 4.9L Turbo Kit Stage 2 Almost Complete. Warren Cyrus 1987 - 1996 F150 & Larger F-Series Trucks 19 08-29-2014 07:18 PM
Garret GT3782V turbo rebuildable??? OriginalOutlaw 6.0L Power Stroke Diesel 11 09-17-2013 05:54 AM
gt3782va smokersteve 6.0L Power Stroke Diesel 4 04-12-2011 03:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
