The AC in my F-150 Super crew Lariat 5.4 was just charged and works fine until the temp reaches ninety degrees, then it blows hot. Does anyone know what this could be?
Fan clutch or blend door acutator. To test if fan clutch , idle the truck to see if it blows hot and put a fan infront of the ac condesnor (radioator) area and see if it blows cold. If not that then the blend door acutator may be the culprit. Those are most common on this truck. You did not state milage so if very high miles than could be clutch gap.
Mine has been doing this since 20K miles and now at 60K it occasionally drips water on my foot while excelerating. Will try Krane Operators method to check this out.
Hey Sugrbug , mine was doing it since the first day i brought her home brand new. If u have water dripping inside , this may help .there is a tsb, technical service bullitn, about adding a ac drain 90.
Thank you so much Krane Operator. I love this site and so thankful I found it. I have 4 issues with my truck and this place covers every one of them. I'm a true Ford fan and will stick with them but I wonder if Gmc or Chevy has issues like the Fords.
