2007 expy major electrical problems
I am going to try my best at reciting exactly what happened. Last weekend I pulled a trailer full of atvs into camp. When we got unloaded I tried to start back up to park the trailer and the truck would not crank/start. I noticed the PATS light was flashing rapidly. So i did some research and discovered that meant my key or transceiver had gone defective or bad battery, but for sure i was not getting the signal to the pcm it wanted. I called ford and they needed it towed in. I then remembered that i had remote start which should have nothing to do with either system and truck should start. Tried remote. No luck. Started messing around under dash by remote module and somewhere between wiggle and jiggle i hit the alarm circuit then remote start and the truck STARTED!! So my guess at that time was a bad battery. When i started driving in to town the wrench came on and put the truck in limp mode. So i drove to the hardware store and bought a new battery. Returned to camp and replaced battery. Still no luck. Started checking fuses and noticed every fuse to the trailer was blown except the 40A brake fuse. Replaced fuses even though they shouldn't affect the truck starting. And when I ohm out the trailer brakes they show a short, so fuse should have blown. Now when i try to start i still get the flashing PATS as well as ALL other faults coming on one at a time. The wrench, battery, over temp, abs, airbag. Oh yeah and the navigation says there is a fault. I got the truck back home and am going to start to tackle this tonight. My first thought is a short in the main harness were the trailer brake transducer wires run beside the data connector to the pcm. Sorry for being so long winded but I am really looking for some assistance and wanted to be as thorough as possible. Thanks Dan
dr cabela
1997-2006 Expedition & Navigator
07-18-2012 08:43 PM
bigredkacy
11-12-2010 02:59 PM
Hard2Hear
10-12-2010 06:58 PM
