Things I'm looking for......73-79 4x4 stuff 390 - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 06-23-2013, 09:22 PM
wooddyusa's Avatar
wooddyusa wooddyusa is offline
wooddyusa is starting off with a positive reputation.
I'm looking for headlight retainers (round) for my 78, headers for my 390 (must be for a 4x4), an intake manifold (edelbrock) for my 390, RV cam, stock washer fluid container with pump, dash pad, and a pair of mud flaps from a semi, power steering pump cap/dip stick.
I'm looking locally but thought I'd throw this out there in case someone has something there looking to get out of there garage. I'll drive about 100 or so miles from salt lake if need be. Post pics or send in a PM with total. If shipped zip is 84096.
Also if anyone can suggest an online source for these goodies new or used I'd appreciate those suggestions as well.
Thanks
Old 06-24-2013, 08:08 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Go here....
http://www.ford-trucks.com/forums/11...mpilation.html
Post #8 scroll 3/4 the way down to "Parts Vendors & Resources" and just start looking....
Other wise I have the small stuff (headlight retainers (round) for my 78, stock washer fluid container with pump, power steering pump cap/dip stick).
Does your p/s pump take the large cap?
Old 06-25-2013, 01:59 PM
wooddyusa's Avatar
Quote:
Originally Posted by 77&79F250 View Post
Go here....
Thanks for the link. please let me know what you would like for those parts shipped to 84096. My power steering pump actually has a small inlet on it. Ill take a photo and send it your way.
Another question for you....I have AC vents in my dash but no AC. Does anyone make a blank or something other than a vent that will go in those holes?
Thanks
Old 06-25-2013, 02:50 PM
77&79F250's Avatar
Used OEM parts guy
I did not know it you wanted new reproduced parts or used OEM stuff, that why I posted the link to all the companies that provide new reproduced parts. Just in case you want new stuff.
Small inlet p/s pump, no problem I know the one you have. As far as the a/c vent block plates, there is no one that makes them as far as I know?
I would think a simple block plate could be made out of aluminium or thin steel and bent on all four sides to slip in there. Or a flat plate affixed in place?
I could probably make some real fast, maybe even out of polished aluminium tread plate, but that might be a little to up town? You can get some small pieces of thin new metal stock at Lowe's and Home Depot....
Usually the cost of the parts and the rest of the details (shipping address) are discussed thru PM (private messages) that's the way the moderators like it.
Old 06-25-2013, 03:57 PM
wooddyusa's Avatar
Just sent you a PM. Thanks
Old 06-28-2013, 08:29 PM
77&79F250's Avatar
Used OEM parts guy
Washer fluid box w/pump, p/s dip stick (small one) and round head light retainers on their way tomorrow.
360 vs. 390....piston talk! Fellenz 1961 - 1966 F-100 & Larger F-Series Trucks 23 12-08-2014 05:51 PM
390 Bending Push Rods DutchmanAZ FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 09-30-2014 12:51 PM
390 Headers Suggestions!! GaRedneck91 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 14 07-31-2014 08:51 AM
390 build with a 391 block parts 59flatbedford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 03-15-2012 07:48 AM
Question about fuel filter on 390 pcskies FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 11-09-2008 06:23 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
