Fuel mileage drop - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Fuel mileage drop
Old 06-23-2013, 08:19 PM
Lil Red Sled's Avatar
Lil Red Sled Lil Red Sled is offline
Lil Red Sled is starting off with a positive reputation.
Fuel mileage drop
I got a 95 f250 7.3 4x4 single can long bed. Just put a Dana 60 up front and 4inch turbo back exhaust kit from mbrp. I used to get around 14 mpg. But ever since I did those things it's dropped to 10.5. Any reason why it would do this?
Old 06-23-2013, 10:59 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Are all the bearings and hubs good in the D60? Could be out of alignment, or have a caliper sticking a little. Make sure the 4x4 hubs aren't engaged. Do you keep your foot in it now to hear that new exhaust? LOL! That will do it for sure! LOL!
Old 06-26-2013, 12:08 AM
Quote:
All new hubs calipers rotors pads ujoints and ball joints. Hubs are free. No I don't. It's been like this the last 3 tanks of diesel. Same commute nothing new driving wise
Old 06-26-2013, 12:14 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Rear brakes dragging maybe.i had a bad parking brake cable holding a brake on...its prob not your problem but throwing it out there
also.what springs did you use front and rear.im windering if big lift maybe wind resistance...i know thats a strech but..
Old 06-26-2013, 07:51 AM
Fordman96 Fordman96 is offline
Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.
I can't really see the new axle weighing a whole lot more then what was under there before so I can't believe the new "weight" is dragging you down.
Old 06-26-2013, 08:17 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Did you get the new axle aligned after you installed it? With as much weight as there is sitting over the front axle on these trucks, the front end alignment makes a big difference in the rolling resistance of the truck.
is there any truth to this supertuff 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-18-2015 08:26 PM
2005 5.4L 3V tensioner islandboy007 1999 to 2016 Super Duty 3 08-05-2014 08:24 PM
i want to double check befor ordering.. quaallen Offroad & 4x4 4 03-25-2011 10:28 PM
Drop pitman arm BIGREDFERD 1999 to 2016 Super Duty 5 08-01-2010 10:46 PM
steering clearance ghostflamed66 1961 - 1966 F-100 & Larger F-Series Trucks 1 01-03-2004 08:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
