Real world use and mpg from a TC 2.0L. - Ford Truck Enthusiasts Forums
Transit Connect 2010+ Ford Transit Connect
Old 06-23-2013, 06:58 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
WOW..... I first got interested in Transit Connects back in 2008, WHAT THE...........
I started a new job this past Tuesday and the round trip is around 50 miles. My poor 4.2L 167,000 mile ladened
F150 is starting to provide lower that desired MPGs. I use around 4 gallons on the round trip and at 4.30 a
gallon, I am considering a used TC (around $20,000 for a 2010 model).
Can the TC with a 2.0 handle around 500 pounds of tools?
Portable tablesaw, chopsaw, extension cords, drills, etc. - pretty much most of my carpentry tools and
equipment.
What kind of real world MPGs can I expect from a 2.0 TC? I spend around 400.00 a month of fuel, but
economically it would not make sense for a TC loan payment and a higher than desired fuel cost from the TC.
The other option is a new 4.2 in the F150.
Thoughts - good, bad, indifferent?
Who has a loaded daily driver Transit Connect? Help!
Old 06-24-2013, 06:25 AM
pbeering's Avatar
pbeering pbeering is offline
pbeering is gaining momentum as a positive member of FTE.pbeering is gaining momentum as a positive member of FTE.
TC payload is a tick below 1700#. Mine scales at 5030# fully loaded. I have seen MPG of low to mid twenties in town.
Old 09-02-2013, 08:12 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
My 2010 sees max lbs regularly, gets 25 mpg running highway speeds, has 167k miles and had no trouble at all out of it.
Old 10-07-2013, 06:46 PM
Little General Little General is offline
Little General is gaining momentum as a positive member of FTE.
My 2011 TC fully loaded with plumbing repair parts doing mixed driving thru Charlotte, N.C. traffic is getting 23mpg with no problems . Just normal oil changes with 25k miles.
Old 11-09-2013, 03:15 PM
FordBlueHeart's Avatar
FordBlueHeart FordBlueHeart is online now
FordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud of
My 2010 TC has a ladder rack on it. I took the ladder off from it because it cost 1-2 mpg. Most of my driving is highway and freeway. Here in Michigan that means 60mph on the highway and 75mph on the freeway. Where I drive can be hilly, never flat for more than a few miles. With that said, the best I ever got for a tank was 23mpg. The worst was just under 20mpg. 75,000 miles on it when I left that job.
Old 11-09-2013, 04:34 PM
ncranchero's Avatar
Mine is at 176K now and still motoring right along, 24-25 mpg.
Old 12-06-2013, 08:25 PM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
Our 2010 has about 16k miles on it, and i believe gets around 22 mpg. Probably be better if your foot wasnt to the floor the entire time, but thats the only way you can get anywhere in it. Barely makes it up some small small CT highway hills here at 70, nevermind with something in the back
We mostly just use it as a transportation for tools/materials to jobs and for errands. the F450s do the work
Old 01-16-2014, 08:11 AM
newstylecustoms newstylecustoms is offline
newstylecustoms is starting off with a positive reputation.
My company truck is a 2013 Connect and only has 6k on it. Every tank so far regardless of how it is driven or where it is driven (usually a mix of city and highway) it gets 24-25 MPG. Not much weight though just small tools and supplies.
Old 01-16-2014, 06:33 PM
ncranchero's Avatar
Mine now is at 185K and still runs and drives solid. MPG's are still 23/24 with my foot on the floor!
Old 02-21-2014, 07:39 PM
Mine is now at 45,000 miles and has no problems other than the crappy tires it came with. I put on a set of top of the line Goodyears and its good for another 45k. I was worried about the truck holding up, so I bought an extended warranty. Also, I bought new for the same reason. Having owned one for a while, I would not hesitate to buy a used one from the cable company / alarm company/ etc. at an auction or lease turn ins.
Old 05-19-2014, 10:22 PM
Van Diemen's Avatar
Van Diemen Van Diemen is offline
Van Diemen is starting off with a positive reputation.
2012 here with 56k miles. Loaded with racks and tools. Not a single issue so far. I've moved close to 2000# (20 bags of Portland cement) on a few occasions. My Mileage mixed city/hwy is 22-25. Got 50k from the original tires (Conti's) and didn't think they were that bad so replaced with same.
This van replaced an '06 F350 Diesel and the money saved on fuel, driving 35k miles a year, almost pays for itself.
Old 05-20-2014, 12:27 AM
ncranchero's Avatar
I'm at 202K now, highway miles mostly. MPG's haven't fallen and still problem free.
My new TC will be here in about 3 months!!
E4OD no TC Lock up javi2001 Clutch, Transmission, Differential, Axle & Transfer Case 4 02-03-2017 11:02 AM
For those that doubt the Transit Connect Parts Jimmy Transit Connect 13 11-04-2015 11:02 AM
4R100 Shifting Issues thadru2001 1999 - 2003 7.3L Power Stroke Diesel 8 07-30-2014 02:36 PM
can you really get the hardened valves in the TC? Mustang Gregg Transit Connect 6 02-03-2012 09:05 AM
E4OD 3-D,D-3 shift LarenceF Clutch, Transmission, Differential, Axle & Transfer Case 7 08-04-2010 01:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
