Such Thing As A 7.3L Performance Head? - Page 2 - Ford Truck Enthusiasts Forums
Old 06-24-2013, 08:31 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
Originally Posted by strokin'_tatsch View Post
I don't know any specifics on how much room there is before hitting water jackets or how they can modify for larger valves, but the valves are already big enough that they are right up against the cylinder walls as it is in factory form. I've heard of some modifying and being able to run larger valves before.
The ports can take a good bit of porting, but the exhaust side doesn't really need much. Just a good clean up. The intake needs a lot of work..
Is porting worth doing if a guy did it his self?
Old 06-24-2013, 08:41 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
All I would do myself is simple cleanup work like smoothing out casting flaws and such. I'm too scared of messing up the flow characteristics. We smoothed out the exhaust side on my spare heads and it took hours upon hours just to smooth them out. These heads are incredibly hard and take forever to get any work done. I don't think it's worth doing yourself unless you know what your doing.
Old 06-24-2013, 08:57 PM
ReBilld's Avatar
I always wondered about porting these heads. I may just do the clean up like you said. Thanks bud.
Old 06-24-2013, 09:17 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
There are shops that port these heads, but an actual new casting for higher performance... No, there aren't any. It would be cool if there was and there would be a benefit. We see pretty good performance improments through porting.
What do these shops charge? Just curious!
Old 06-24-2013, 10:13 PM
Quote:
Usually around $1000-4000 depending on how crazy your going. Call up Diesel Innovations and ask them what they would charge. I haven't talked to David about porting mine yet, but he is who I'm going to use on mine.
I just checked Empire and they charge $1000 for a "improved street" port, $2000 for a "hot competition port", and $4000 for a "full race" port.
Old 06-24-2013, 10:22 PM
WOW........
Old 06-24-2013, 10:59 PM
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
My better halfs uncle is in the process of building a pulling truck with a 99-03 7.3L. Between him and his brother, theyre basically car geniuses. They've discussed the heads several times. I haven't been in on most of it so Im definitely going to pick his brain when he gets done with his set!
Old 06-25-2013, 06:42 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Porting is real expensive, especially when you're talking cast iron and not aluminum. I've got a set of iron heads from back in the day that have over 200 man hours into porting them. This was done 30 years ago, but just sayin'. He got a little deep on one and hit a water jacket, but its been fixed.
Doing much porting at all is quite dangerous unless you know what you're doing. I burned through a 351w head before.. You gotta know where it will help, and where it will hurt. A flow bench is required to do it right. If the valves are that close to the cylinder walls the way they use bigger ones is notch the cylinder for clearance.
Old 06-25-2013, 08:57 AM
Quote:
Thought so. Sounds like a PITA.... Think I will just add more nitrous. LOL
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
