rear differential over heating problem
Old 06-23-2013, 05:17 PM
reesecup's Avatar
reesecup
reesecup is offline
Hi, I have been having a rear diff. / speed / abs sensor problem when towing (not that heavy) loads. Either the rear diff. is over heating and causing the sensor in housing to fail, or vise versa. The ABS light comes on then shortly after the speedometer starts going bezerk. then the transmission stops knowing when to shift causing over heat. Put a new sensor in then its fine for awhile. Trying to get to the problem cuz sensors are getting to be an unwanted expense. gear oil is full, 80/90. Really appriciate any suggestions, nervous and on edge every time i get in it wondering if its going to get me there or not. Never happens when not towing. dont use overdrive while towing, no worn gear or rear end noises, no leaks. Thanks for any help! Reesecup, Ohio
Old 06-23-2013, 07:27 PM
zombie_killer's Avatar
zombie_killer
zombie_killer is offline
There are rear diff cooling systems that can fabbed to facilitate cooling of your gear oil. But to my knowledge most of the electric pumps that these kits use are for intermittent use at high temps.
I wonder if you have a limited slip and if so, do you have the additive required for it? This may help to control fluid temp. Sorry I am not too much help.
Old 06-23-2013, 07:51 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Is your truck a 1/2, 3/4, or 1 ton.
When is the last time you changed your fluid.
Do you have access to a inferred heat gun?
Old 06-24-2013, 01:23 AM
reesecup's Avatar
reesecup
reesecup is offline
Hello, truck is 460 fi, dually 1 ton. Never changed the gear oil and ive had truck for 3.5 years. no access to heat gun but could check with my mechanic about his access to one. thanks for your assistance.
Old 06-24-2013, 01:26 AM
reesecup's Avatar
reesecup
reesecup is offline
i did pull plug out and added some gear oil last sensor change, it took about 1/3 quart at most until it ran out of plug hole located about halfway up the housing.
Old 06-24-2013, 01:28 AM
reesecup's Avatar
reesecup
reesecup is offline
hi, not sure on the limited slip? its a 460fi dually, 1 ton.
Old 06-24-2013, 04:13 AM
Diesel_Brad
IIRC the sterling rear axle takes 75-140 oil
I would change it and while you are in there look over the internal components
Old 06-24-2013, 07:43 AM
reesecup's Avatar
reesecup
reesecup is offline
ok, the truck is currently sitting at the Kentucky nascar track. when ive changed sensors there wasnt much on metal shavings attached to the sensor magnet. To change oil i noticed no drain plug so im assuming the back plate has to come off to do this? I sell food at the race tracks, hoping i can get this thing home 4.5 hours to central ohio to take it to my service garage. The truck did this last fall and by chance happened to break down by ford dealership, they cost me 2,000 for a transmission rebuild that i dont even think i needed. Noticed the black heat protector around the sensor wires was hot, melted and in bad shape, i rerouted wires as far away from diff. housing as i could and taped the wires up good. im just wondering if somehow the sensor is shorting out somehow (possibly the tow trailer lights)? last sensor change i left trailer lights unplugged and it went on to race track without issue. I can laugh now but i also dropped the sensor bolt (hot) and it fell straight through the sensor mounting hole on top and i thought at that point the game was over lol. ws able to get a magnetic scope and the bolt came right up out of there!.... Reese
Vettestir
1999 to 2016 Super Duty
02-07-2011 09:34 AM
av226
04-24-2009 05:34 PM
conkster
09-09-2006 12:05 PM
penfold2301
10-27-2005 08:30 AM
TexasGuy001
10-25-2005 06:33 PM
Quick Reply: rear differential over heating problem
